Petcock markings....what?
- polkat
01 Feb 2010 19:37
This will sound stupid I know, but i just took a good look at my tank's petcock for the first time and I'm a bit confused by the markings. To the front is marked RES, down is marked PRI, and to the rear is marked ON.
So...where should it be when I park it for a long time, and where should it be to run? And finally, what is PRI? Had a guy tell me to move it back (to ON) when parking it, but that doesn't make sense to me. Anyone know these markings?
- TerryK
Re: Petcock markings....what?
01 Feb 2010 19:44
RES = reserve
PRI = prime
PRI = prime
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- TeK9iNe
- What did you do!?!
01 Feb 2010 20:05
You have a vacuum operated petcock that relies on the engine vac to open a diaphram in there which in turn allows the gas to flow.
The default setting is ON. While ON the gas will not flow unless the engine is running. ON position draws gas from slightly higher up in the tank than RES.
RES is your reserve setting that will also no flow gas unless the engine is running. You flick the petcock to reserve when your bike strarts to sputter in the ON position, the you get yer butt to a fuel station quick!
PRI is the prime position that will provide unrestricted fuel flow no matter if te engine is running or not.
You can disconnect your lines without fear of gas flow in either the ON or RES position.
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JakeB
01 Feb 2010 20:11
It's a vacuum style petcock, meaning it uses engine vacuum to actuate the valve.
So the guy that told you to turn it to "ON" while parked was correct. While in the "ON" or "RES" position the valve will be closed until engine vacuum is present. "PRI" or prime as TerryK mentioned, bypasses the vacuum and opens the valve to get fuel to the carbs if they are empty for some reason.
Hope this helps
Hope this helps
1978 Z1-R
- polkat
01 Feb 2010 23:12
How long dows it take the PRI position to fill the carbs if the bikes been parked till dry?
- fixer5000
02 Feb 2010 13:59
polkat wrote:
about 10 seconds
about 10 seconds
1978 kz650b pretty much stock
massachusetts
massachusetts
- TeK9iNe
02 Feb 2010 15:54
Yeah, very quickly.
You really dont need to use prime ever unless you are installing the tank after some work/maintenence or something.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- grumpy56
02 Feb 2010 16:19
A related "trick" here is what is "ON" and what is "RES" in relation to the position of the lever. My owner's manual is incorrect (1982 1000J2). The "arrow" on my handle points to the appropriate position.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- jeffasaki
02 Feb 2010 16:29
Who was it that decided to call a selector valve a petcock.Ive always had a problem calling anything a petcock.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
02 Feb 2010 16:43
Now that I think about it I think about a petcock was used to tap a keg they would put it in the Bung Hole and have a drink.I kinda like the fact that I have a vacuum actuated one
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
