Updating Carb system!!!
- jacosort1
27 Jan 2010 14:24 #344937
by jacosort1
Updating Carb system!!! was created by jacosort1
Well, this long Minnesota winter is driving me crazy. so i got a project to keep me buisy!
I am currently working with a 1976 kawasaki kz400. Mostly stock besides and aftermarket exhuast kit (2 into 2). BUT, i would like to run an oversized carb set up, and my question is - WILL IT BE POSSIBLE TO RUN A 38MM CARB OFF OF A 1978 YAMAHA XS650, ON MY KZ400? and also if it is possible will it be worth my time to do?
- moneypit
- Thank you received: 35
27 Jan 2010 17:54 #344979
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Updating Carb system!!!
I would have to say NO, Theres no way that your intake would flow enough for carbs that big. A 900 stock would have a hard time with those I would think but some one with mors knowhow should chime in. By the way where in this cold state are you. BobB)
2-76 kz900
St Paul MN
- keith1
- Thank you received: 2
27 Jan 2010 17:58 #344981
by keith1
Replied by keith1 on topic Updating Carb system!!!
wayyyy too big and the spacing would probably be off....
- jacosort1
27 Jan 2010 18:10 #344983
by jacosort1
Replied by jacosort1 on topic Updating Carb system!!!
moneypit - thanks for the advice and reply! i am an amature ya gota give me a break! ha But i am from anoka county, i take it your from these parts?
keith1 - might you have any clue or suggestion to the size i should look for or consider? thanks again!
- PLUMMEN
- Thank you received: 104
27 Jan 2010 18:35 #344988
by PLUMMEN
Replied by PLUMMEN on topic Updating Carb system!!!
something more in 24-26mm range i would think if running 2 of them ,i cant remember what that 400 i parted out had for carbs
- jacosort1
27 Jan 2010 18:58 #344993
by jacosort1
PLUMMEN - thank you very much! i sh'all use this information wisely
- moneypit
- jacosort1
27 Jan 2010 19:03 #344997
by jacosort1
moneypit - you wouldnt happen to visit first thursday!?
- flht1997
27 Jan 2010 19:33 - 27 Jan 2010 19:47 #345009
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic Updating Carb system!!!
The 74'-76' 400's ran 36mm with the later ones going to 32's. The yamaha ones probably will not have the proper spacing, also the spacing is different between the early and late 400's and will not interchange. Oh and by later I mean 1977 and newer with had a slightly different engine
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
Last edit: 27 Jan 2010 19:47 by flht1997.
- jacosort1
27 Jan 2010 19:38 #345010
by jacosort1
flht1997 - thanks for that insight! but what would you suggest i tear the carbs from, really lost now and dont know what to look for??
- flht1997
27 Jan 2010 19:45 #345013
by flht1997
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
CVB36's from a 74'-76' kz400 will fit. They have a metal slide so you do not have to worry about a rubber diaphragm going bad. Z1 enterprise has carb kits for them once in awhile. They are kinda a pain to clean with lots of little jets and air bleeds all over the place but quite do-able
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- jacosort1
27 Jan 2010 19:58 #345015
by jacosort1
thanks for the input
