Carb Removal
- miketrez
Trying to repair an oil leak from the head journal. Need to remove the head to replace it and I am stuck with how to remove the carbs without damaging the choke/throttle linkage. Can anyone offer any help, hints, or tricks for this?
Thanks,
Mike
82 KZ750 Spectre, Shaft Driven
- keith1
- Thank you received: 2
- Thank you received: 2237
First of all, get a factory shop manual, it will save your bacon many times over.
Secondly, there should be no danger to the throttle and choke linkages since the whole set of carbs and linkages come off as an assembly.
In general, you will need to remove the fuel tank and its hoses, and disconnect the throttle and choke cables from the carb assembly. If you have the stock airbox, you will need to loosen all clamps and / or springs that hold the various boots and manifolds to the carbs. Finally, you will need to rassel (that's Texan for wrestle) the carb assembly off the intake boots and intake manifolds. Be very patient, especially if the rubber has hardend.
Like Kieth1 said, the procedure will vary depending on the particular model involved. Good luck and stock up on beer and band-aids.
- roy-b-boy-b
- Thank you received: 103
Plenty of help here.
I always remove the carbs then remove the linkage. Can do do that on your bike?
Does it have the stock air box?
You could do a search on your bike in the carb section. Just click on forum and all the catagories will come up. Roy
- miketrez
I have a 82 750 Shaft drive.
It does have the stock air box. I tried pulling on the assembly with no success. However, I did not muscle it too much in fear of breaking the linkage. Will try again today.
I saw a picture of another rider that had put on independant air clearners directly onto the carb throat. Looked like something K&N might sell. Any one have any opinions/sources for that setup?
Also, Since I have this torn down this far, I would like to replace the piston rings. I cannot find the proper rings for the stock pistons. Anyone have a source for those?
Thanks,
Mike
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Thank you received: 2829
- roy-b-boy-b
If the bike has set up for a while the rings might be stuck. Rings are expiensive. Roy
- miketrez
I am the third owner of this bike and I do not know the past maintenance history.
It does burn oil, not in large quantities though, but I can smell it. I would like to repair all of the issues at once rather than have to do it again in the near future.
I am speaking about this before I have even opened up the head. As far as i know they may not need to be touched. If they do I would appretiate a source if anyone out there has one. I have searched and aside from the OEM I cannot find them.
Mike
In brief, pods are great when you need to remove and reinstall the carbs and have a cool look and sound. They also necessitate re-jetting and tuning the carbs and can also shorten the life of the intake manifolds unless a support is fabricated.
miketrez wrote:
Thanks Guys!
Thanks,
Mike
- miketrez
Also, during my first attempt the cylinders became unseated for just a quick moment and leaked a bit of oil (oil was drained prior to begining the project). Might this comprimise that gasket? I have a full on gasket kit and changing it out would not be too difficult at this point minus getting the pistons/rings back in place.
Almost there!!!!!
- roy-b-boy-b
