KZ 440 Carbs
- ocularyss
24 Jan 2010 11:43 #344307
by ocularyss
KZ 440 Carbs was created by ocularyss
Greetings and salutations,
I am laying myself at the mercy of the experts. I have a 81 kz440 project that I am trying to get back onto the road. I am planning to run a single carb on this project, but I am unsure what style to run. I wanted to use a Mikuni and the smaller the better. Anyone that can give me some guidance on size/jets/needle shims or anything that may be helpful.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Jan 2010 14:31 - 24 Jan 2010 14:32 #344340
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic KZ 440 Carbs
Good luck my friend.
I don't recommend that configuration personally. As different cylinders have different requirements all throughout the throttle/rpm range, and you wont achieve great performance unless you use individual carbs.
You can run a single carb configuration if you must... but why?
I would think that one of the origional carbs with its origional jetting will be fine.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Jan 2010 14:32 by TeK9iNe.
