Mikuni 33 smoothbore Question
- dragnkaw1428
19 Jan 2010 21:25 #343577
by dragnkaw1428
Andy
Mikuni 33 smoothbore Question was created by dragnkaw1428
In yalls opinion whats the besst jeting and needle hight for the 33 smoothbores on a 10.5 comp. 1105 motor with stock cams
Andy
- dragnkaw1428
21 Jan 2010 20:48 #343850
by dragnkaw1428
- timebomb33
- Thank you received: 10
21 Jan 2010 21:09 #343852
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Mikuni 33 smoothbore Question
id like to help but all i've ever run is 29 smoothies or 40mm lectrons i can call a friend who is running them on a 1166 gs suzi. if you would like, the set-up should be close.
- dragnkaw1428
21 Jan 2010 22:13 #343855
by dragnkaw1428
Andy
Replied by dragnkaw1428 on topic Mikuni 33 smoothbore Question
IYa ive got a set of lectrons on my dragbike they are the best set of carbs ive ever owned. The smoothbores are on the streetbike. I would like to find a set of RS 34's for it. If its not to much trouble to call him I would really apreciate it.
Andy
- Thank you received: 2098
22 Jan 2010 05:10 - 22 Jan 2010 05:16 #343885
by Patton
Replied by Patton on topic Mikuni 33 smoothbore Question
For additional insight if not already done,
search 33 smoothbore jetting
which returns several very informative earlier threads
on tuning and setup of Mikuni 33 smoothbores.
Good Luck!
Good Luck!
Last edit: 22 Jan 2010 05:16 by Patton.
- Old Man Rock
- Thank you received: 225
22 Jan 2010 05:11 #343886
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Mikuni 33 smoothbore Question
Opinions, here, naw...... :woohoo:
If you were to use the search function, you'll find carb jetting postings are abundant. The answer is tricky due to all the variables that change the answer...
Elevation, head porting, head work valves/sizes, head CFM, exhaust/pods, intake manifold conditions, as you have mentioned compressions and top end builds, float height settings etc....
What jets do you presently have installed, what's your performance issues Low-mid-WOT, what's your spark plug conditions, popping/pinging out the exhaust etc...
See, what worked on my engine may not be the BEST on your engine... Sure, they could possibly get you close but spot on, no way.... Then there's the pilot/air screw settings to contend with....
All in all, start with stock jets and work from there or.... as Tek9 recommended, take it to a Dyno/carb tuner and have them set it up dead on for you...
Since this topic was just brought in my jetting project, I compiled for sharing several documents I found interesting and beneficial in learning the art of jetting... Concept pretty much the same for all carbs.
Maybe it will help...
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
22 Jan 2010 08:04 #343916
by timebomb33
do your 33's have an accelorator pump kit installed. because gerry's do so his pilots and needle heights may not work for you.
