Throttle cables?
- 1000J
15 Jan 2010 00:00 #342948
by 1000J
Throttle cables? was created by 1000J
I have been having a problem trying to find throttle cables to work with the 36mm Mikuni flatslides on my 81 Kz1000J.I'm using the throttle housing from an 85 Zn1100B because I need to have push/pull cables and the LTD housing looks stock.I have the seperate housing and cables that came with the carbs but don't like the look.Even had MotionPro make me a set but they don't work,I obviously measured them wrong.Anyone else that has done this swap have any suggestions? After over a year I'm almost finished the restoration so I can't wait to ride.
Thanks for any info.
- 9am53
- homebrew, and some bbq
- Thank you received: 3
15 Jan 2010 04:47 #342953
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic Throttle cables?
no idea, but nice motor!
'84 GPz900r
'71 CB350
- timebomb33
- Thank you received: 10
15 Jan 2010 10:33 #342978
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Throttle cables?
you will probably end up using the motion pro throttle housing with those carbs looks be damned it is safety first.
- pburnhamb
- Thank you received: 2
15 Jan 2010 11:02 #342982
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Replied by pburnhamb on topic Throttle cables?
Damn! nice lookin' motor. don't know if this belps but i've had good luck cutting the housng& grinding, put new caps/stops at the end of the housing (metal ends) and I located these barrels that go on the cable with an allen screw. They have been working for years, but someday I'd like to have a mould to make new barrels.
By housing you mean the sheath that goes over the cable right? sorry if i misunderstood u and wasted ur time reading this!
good luck
-patrick-
good luck
-patrick-
1976 kz900
1977 xs650
