setting floats
- sr man
- Hawk
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
- bill_wilcox100
- Thank you received: 5
See the Fuel Service Level diagram (always check your FSM for your model's specifications):
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- bill_wilcox100
Some members have found ingenious ways to make inexpensive Fuel Service Level tools that they say have worked well for them.
Best of success.
Bill
Upgrades:
Montreal, Canada
- Bluemeanie
- Thank you received: 14
This tool you asking about costs $37.21 + S&H
This "proper" tool costs $69.88 + S&H
This tool is also the "proper" tool and only costs $8.96 + S&H!!
I used this picture and set my floats and worked great!!
Do it once the right way and they will stay adjusted forever until you change something! Good luck....
The $8.95 tool is available here!
- JMKZHI
- Thank you received: 48
Check yours first to see where they are. You could use a homemade fuel level gauge - tubing shoved/screwed into the drain screw hole may work fine. The auto parts store might have a plastic vacuum fitting that can be used along w the tubing... either retap the threads first or just screw it into the hole... a little leakage is okay or use teflon tape to seal it.
That tool from Z1 sets the float level via the inverted/dry method w the carbs placed upside down & the float bowls removed. I meticulously set mine dry, then checked the fuel level in each carb: they were all different. So I redid the job wet.
I made a simple carb stand (a bench vise would work too) so that I could mount/unmount the carbs quickly for fueling. Since you may have to remove/reinstall the bowls numerous times for each carb, it saves time to use ony one or two bowl screws (instead of all 4)... and there's no need for the screws to be real tight. I made a simple support for the floats to make bending the tang easier... I actually flexed the tang witout really bending it.
Flex flex flex flex flex, reinstall the float-&-etc, put on stand, add fuel, check. Etc etc etc.
- Galactica
- Thank you received: 2
77KZ1000
76 KZ900
- Kawickrice
- Thank you received: 18
Bluemeanie, where do you get the $8.96 float level tool?
I just bought the same one for the same price on ebay last month
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Galactica
- dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If your picky and want the levels exact, the ONLY way is the wet method (fuel height) tool. Which in turn will yield the best results.
You dont need to buy the tool for the wet method though. Just wrap some teflon tape arount the end of a tube that fits snuggly in the drain hole and thread it in. It works great.
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- sr man
- Hawk
I went ahead and used a old head and mounted the carbs leveled them so there the same as on bike then checked the floats with the nipple and hose they all were high.
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- bill_wilcox100
Great Idea
Good stuff!
...and the before and after results were? :dry:
Best of success.
Bill
Upgrades:
Montreal, Canada
