- Thank you received: 88
Pilot jets stock Z1 w4into 1
- GregZ
09 Jan 2010 13:11 #342369
by GregZ
Pilot jets stock Z1 w4into 1 was created by GregZ
I'm going through carbs for my 73 Z1 Motor.It is all stock/airbox and will use my 4-1 yosh or a new chrome kerker.I plan on one size up mains to 115's. the carbs already have 25 pilots,should I use them or replace with stock 20's
gregz
gregz
- Thank you received: 2098
09 Jan 2010 13:45 - 10 Jan 2010 13:57 #342370
by Patton
Replied by Patton on topic Pilot jets stock Z1 w4into 1
GregZ wrote:
Here's some info from Z1E:
28mm (VM28SC) Z1 & early Z1-A
Main Jet 112.5
Air Jet 1.0
Needle Jet P-8
Jet Needle 5J9-3 - last number is the clip position where 1 is at the top of the needle (leanest) and 5 is at the bottom (richest)
Throttle valve (slide) 2.5mm cutaway
Pilot Jet 20.0
Air Screw setting 1 1/2 turns out
28mm (VM28SC) Late Z1-A & all Z1-B
Main Jet 112.5
Air Jet 1.0
Needle Jet O-8
Jet Needle 5J9-2 (last number is the clip position)
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5
Air Screw setting 1 1/4 turns out
Good Luck!
Edit --
Oops, confirming the already known oem pilot size doesn't help answer the question. :blush:
Wondering why the oem 20 pilots were replaced with larger 25's in the first place?
gregz
Main Jet 112.5
Air Jet 1.0
Needle Jet P-8
Pilot Jet 20.0
Main Jet 112.5
Air Jet 1.0
Needle Jet O-8
Pilot Jet 17.5
Good Luck!
Edit --
Last edit: 10 Jan 2010 13:57 by Patton.
09 Jan 2010 14:47 #342378
by Patton
- mtkawboy
- Thank you received: 16
10 Jan 2010 12:31 #342471
by mtkawboy
Replied by mtkawboy on topic Pilot jets stock Z1 w4into 1
The 20 pilots on the 73s were the largest pilots ever used on the Z1 & KZ1000 series of bikes. I ran mine in 73 with stock pilots and the 115 mains with the airbox on but the filter out at the drags. Went 12.19 @ 108.95 going thru in 4th that way. Not much now but damn fast back then for a stocker with a pipe. This was at sea level in Miami Fl.
