what to do 77 kz1000
- kzbasket
- keith1
- Thank you received: 2
my ride has sat for a month.i wanted to go for aride but it will not idle.i don't think that the gas would go bad that fast.called around and everybody said rebuild the carbs,at about $300.00.what can i try?
if it s only sat a month the carbs should only need a light cleaning, if at all.pull the bowls and spray the jets with carb clean....check the plugs...if old...put in a new set..
battery good?....if you dont get 12v across pos and neg with a volt meter set at 12v or higher, battery is toast..
a toasted battery will do funky things.........
- roy-b-boy-b
- Thank you received: 103
Gas will not set for any time now. Roy
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kzbasket
this weekend I pulled the float bowl's off,cleaned used carb cleaner on the main jets and pilot jets,blew them out with compressed air. reinstalled with new gaskets. put some sea foam in the tank about 2oz. runs better but the idle is still bad.should I put more sea foam in it ? and how much ?
thanks kzbasket
- roy-b-boy-b
Adjust the idle up until it clears out. Roy
- kzbasket
- PLUMMEN
- Thank you received: 104
- KTA
Seafoam is a great product - but at the same time it is no magic cure.
If I was you I'd run a can of seafoam through the tank. If the idle is still rough after you're going to have to break down and clean the carbs. Likely it's just a clogged pilot jet which is easy enough to clean.
When the bike first fires up and you haven't revved it, feel the headers. Is one or two of them colder than the others?
- Old Man Rock
- Thank you received: 225
Seem like something I'd do anyways...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
you just like taking carbs apart! :laugh:Any reason why you can't soak the jets over night in the Seafom itself?
