Pods Emgo
- KayZee650C3
04 Jan 2010 23:09 #341860
by KayZee650C3
Pods Emgo was created by KayZee650C3
My kz650c3 was running perfect...Installed emgo pods that's it. Now she cant take much throttle, I have to get on it very gentle, otherwise she boges down...
- roy-b-boy-b
- Thank you received: 103
05 Jan 2010 04:31 #341866
by roy-b-boy-b
Replied by roy-b-boy-b on topic Pods Emgo
Welcome aboard!
Fill in your signiture with the model bike you are riding and it will help us help you a whole lot quicker.
Did you increase your jet size? You increased your air flow installing the pod filters so you must also must increase your jet size.
There are a lot of 650 riders here that can help you in choosing what size you need. Roy
- Thank you received: 2829
05 Jan 2010 06:08 #341874
by 650ed
Replied by 650ed on topic Pods Emgo
Pods :laugh: :laugh: :laugh:
- otakar
05 Jan 2010 06:20 - 05 Jan 2010 06:22 #341878
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Pods Emgo
In 1981 those carburetors were tuned extra lean. Increase your main jet size 2 sizes and raise your needle two notches. also richen up your pilot screws 1/2 turn.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 05 Jan 2010 06:22 by otakar.
- anarki650
- Thank you received: 5
05 Jan 2010 15:49 #341927
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Pods Emgo
When I had the exact same set up (emgo pods, stock exhaust, on an 81 with no other mods) I had to increase main jets to 112.5 (4 steps over the 102.5 that will serve for stock jetting on just about all stock 650s, some years were jetted much more lean than that from the factory down in the low 90's for main jet sizes). Also had to bump up to 17.5 pilots. Don't believe that the 81 carbs have adjustable needles in them, you can either get needles out of rebuild kits for earlier model carbs or shim them a bit. I believe z1 sells shims for the needles.
With that set up my plug chops were perfectly tan through all circuits of the carbs. I'm in Omaha NE if you're wondering about my elevation.
09 Kawasaki ER6n
Omaha NE
