leaking
- irish mike
- 79 kz 650 b3 rat rod
03 Jan 2010 07:46 #341691
by irish mike
leaking was created by irish mike
hi everybody i thought i had my 79 kz650 dialed in and ready to go[pics comming soon] but heres the deal- bike runs great but when i stop and park it about 4 or 5 hours later i find a spot of gas under the bike -[with petcock in the off position]it seems to be just the gas in the carbs thats leeking out -especially when its on the sidestand the drain on the sidestand side is the only one that leeks [i think]could it be the float valve seals [ivereplaced juist about everything else in the carbs and cleaned them no gas comes out while bike is running like i said its uasually about 4 or 5 hours later when i notice the spot of gas thanks mike..
- Kawickrice
- Thank you received: 18
03 Jan 2010 08:17 - 03 Jan 2010 08:20 #341692
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic leaking
Sounds like the petcock is leaking and the needle and seats probably need to be replaced too
Float level could be on the highside also.
Mine did that and it was the petcock even after a rebuild. I had to take off the tank and let it sit overnight to find the petcock was the culprit
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 03 Jan 2010 08:20 by Kawickrice.
- Thank you received: 2829
03 Jan 2010 15:39 #341713
by 650ed
Replied by 650ed on topic leaking
You can pull the overflow hoses up to where you can see them well and positively identify which carb(s) is leaking. That way you won't spin your wheels working on carbs that are ok. Once you identify the leaker, assuming that it's leaking through the overflow, make sure the overflow "tube" inside the carb bowl isn't cracked or damaged. Some members have had that happen and the carb leaked the fuel that normally just rests in the carb bowl. Ed
- irish mike
10 Jan 2010 19:02 #342516
by irish mike
Replied by irish mike on topic leaking
yup it was the petcock all right[cant believe it -its brand new ] guess ill buy a new one from z1 and see if anything else needs to be done after that -thanks all mike ....
