I have a set of 77 KZ 1000 carbs
- KZ1000GClassic
28 Dec 2009 20:47 #341018
by KZ1000GClassic
I have a set of 77 KZ 1000 carbs was created by KZ1000GClassic
I have a set of 77 KZ 1000 carbs , these were done by a very worthy mechanic, my difficulties is that the float bowls seem to leak. I took the bowls back off and made sure the gaskets were in place and such and putthem back together. They still leak in areas! I am not that familiar but and handy enough to pull them back off and retry! Any suggestions on anything please?
- Kawickrice
- Thank you received: 18
28 Dec 2009 21:13 #341022
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic I have a set of 77 KZ 1000 carbs
It is probably time to replace the bowl gaskets. Once they dry out and get brittle they seem to seep alot around the edges.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Martynbiker
- 1993 KZ1000P
29 Dec 2009 04:00 #341034
by Martynbiker
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
Replied by Martynbiker on topic I have a set of 77 KZ 1000 carbs
whatever you do... DO NOT use sealant!!!!!! use NEW gaskets. your frustration levels and blood pressure will eventually thank me for that advice...... DAMHIK.... lol
- BSKZ650
- Thank you received: 14
29 Dec 2009 06:46 #341049
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic I have a set of 77 KZ 1000 carbs
along with new gaskets, make sure the bowls are flat, the screw hole area can become raised from someone wrenching down on the screws.
This can be fixed be either a file, or fix some sand paper to a board, a few passes should flatten the area out again.
- PLUMMEN
- Thank you received: 104
29 Dec 2009 12:05 #341095
by PLUMMEN
Replied by PLUMMEN on topic I have a set of 77 KZ 1000 carbs
- will61310
- Thank you received: 6
29 Dec 2009 13:24 #341112
by will61310
...1980 LTD 1000...
Replied by will61310 on topic I have a set of 77 KZ 1000 carbs
Which flavor works the best?
...1980 LTD 1000...
- PLUMMEN
29 Dec 2009 19:20 #341151
by PLUMMEN
depends on whos gasket youre kissin! :laugh:
- Old Man Rock
- Thank you received: 225
30 Dec 2009 08:48 #341187
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic I have a set of 77 KZ 1000 carbs
Here's what Ive been using on the carb intakes to seal for vacuum loss and would work here (rubber gaskets) as well....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
