vacuum hose diagram
- The_New_Kid
26 Dec 2009 10:21 #340751
by The_New_Kid
'99 GMC Suburban K1500
'83 Kawasaki KZ550 M LTD
Lifes journey is not to arrive at the grave safely and in a well preserved body, but rather to skid in sideways, shouting ''Holy sh*t, what a ride!''
vacuum hose diagram was created by The_New_Kid
I have looked and can't find a diagram for my 83 550m. can anyone help? thanks in advance
- loudhvx
- Thank you received: 1616
26 Dec 2009 11:45 #340756
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic vacuum hose diagram
Well, I can't help with the ones going directly to the carbs, but there are some for the big emissions contraption above the engine. That thing should have one or two (usually two) small vac hoses going to the intake manifolds. Those two control the air-suction valve. It's a diaphragmin a metal case up on top of the motor. There will also be two half-inch hoses going from the air-suction valve to the valve-cover. There will also be a larger hose going all the way back to the airbox. Really, all that stuff can be removed as long as you plug all of the holes that had hoses connected. Don't throw it away in case you need it some day (unlikely). when that system gets defective, it usually results in a lot of backfiring through the exhaust.
1981 KZ550 D1 gpz.
Other links.
- The_New_Kid
26 Dec 2009 12:45 #340759
by The_New_Kid
Replied by The_New_Kid on topic vacuum hose diagram
well, heres what I found, is it right?
1:into the "T" thing
2:petcock
3:plugged
4:same as #1
2:petcock
3:plugged
4:same as #1
- Thank you received: 2098
27 Dec 2009 07:15 #340818
by Patton
Replied by Patton on topic vacuum hose diagram
Here's the '83KZ550 Spectre air cleaner diagram from kawasaki.com. Perhaps it might help.
Good Luck!
[Click on image to enhance view.]
Good Luck!
- The_New_Kid
27 Dec 2009 09:02 #340840
by The_New_Kid
Thanks guys! I think I got it figured out.
- loudhvx
27 Dec 2009 10:37 #340844
by loudhvx
1981 KZ550 D1 gpz.
Other links.
The_New_Kid wrote:
That's sounds right from what I remember.
2:petcock
3:plugged
4:same as #1
1981 KZ550 D1 gpz.
Other links.
