- Thank you received: 7
Rejetting CVK30s where 2&3 mains are > 1&4
- pyxen
23 Dec 2009 09:17 #340401
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
Rejetting CVK30s where 2&3 mains are > 1&4 was created by pyxen
Hi,
So I've got my ZR550 carbs sitting split open on my bench in the basement, and before I put them back on the bike I want to rejet to increase my main size.
Right now it's jetted to (1-4) 108, 110, 110, 108, to account for hotter middle cylinders. If I get 5 115s from Z1, would I be messing with it too much? It's got a 4 into 1 stock exhaust on it, but I'm looking at putting pods on.
I taped up about a 3rd of the air filter for the latter half of the season and had great tan plugs, but no power.. so I figure an unobstructed air filter and larger mains will be really sweet..
So - 115s all across, or should I just go 112/115/115/112?
As soon as I can get this buttoned up, I can start on my KZ550 again!
84 KZ550-F2 LTD
93 ZR550-B4
- Nebr_Rex
- Thank you received: 300
23 Dec 2009 11:28 #340409
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Rejetting CVK30s where 2&3 mains are > 1&4
My ZRX came stock with staggard(?) jetting,now it is jetted the same across from 1 thru 4 and runs fine.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- pyxen
23 Dec 2009 13:31 #340419
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
Replied by pyxen on topic Rejetting CVK30s where 2&3 mains are > 1&4
Okay.. so now the question of size remains.
Is 108 to 115 too big of a jump, or should I go up to 112 on all 4? Z1E doesn't stock 112s, which is why I'm leaning to 115s, and it seems that going up by 5 is the norm...
84 KZ550-F2 LTD
93 ZR550-B4
- Nebr_Rex
23 Dec 2009 14:25 #340420
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
try 110,raise the needle one groove,if no grooves one washer about 1/16 in.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- timebomb33
- Thank you received: 10
23 Dec 2009 15:23 #340425
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Rejetting CVK30s where 2&3 mains are > 1&4
if you had to tape up the intake to get a decent burn then i'd want to make a major step in oppisite direction at least 2 or 3 sizes go for the 115's, 110's would be just taking baby steps that is clearly not what you need to do in this situation.
- pyxen
24 Dec 2009 06:31 #340513
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
The middle two cylinders are already 110s, so I think 112 at the least. I'll order 4 115s from Z1E and see what happens (can't really ride it now anyways, since winter is in full effect up here.)
To be clear: I didn't tape up the intake, I taped the actual filter. I reduced the perforated surface area using duct tape.
84 KZ550-F2 LTD
93 ZR550-B4
