- Thank you received: 2
How important is that #2 vacuum plug?
- sakiguy
1983 KZ750 N2 Shaft
- rstnick
- Thank you received: 377
Without it would lean out that cylinder which could cause some problem, maybe even hole a piston. :ohmy:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Jeff.Saunders
By running lean on that one cylinder, you could have caused the piston top to start to melt - and the first sign of that is those specs of aluminum on the spark plug.
www.z1enterprises.com
Z1 Ent on Facebook,
- sakiguy
I don't see any specs of aluminum on the spark plug but the little tip is white. Should I just change the whitish spark plug then?
Alright, this is what the #2 spark plug looks like right when I removed it to check. The tip is very white.
I will say that I did ride around after putting the plug back on before removing the spark plug and taking a picture. The bike was really riding nice. Feels very strong, and pulls. I also want to reiterate that the vacuum plugs on the #2 vacuum tube is a plug about the size of a valve stem cover. When I did ride without the plug it was about a 14 mile street ride going about 45mph...with a 10 minute stop...and then 14 miles back home.
1983 KZ750 N2 Shaft
- savedrider
- 1975 Z1-B 900
- Thank you received: 1
Get right or get left! <*{{{><
- Thank you received: 2098
Good Luck!
- KZ250LTD
- Thank you received: 16
Just as a preview of what can happen with a lean issue:
:S
79 KZ1000ST
Past:
Many.
- sakiguy
On one note, I think I did have the idle adjustment screw set too high when I did run without that plug...so perhaps this created some kind of balance and saved that one piston from running to lean or whatever? Because when I put that vacuum plug back on I had to back down on the idle adjustment screw to get the idle right.
1983 KZ750 N2 Shaft
- Kawickrice
- Thank you received: 18
Other than the leanness, that plug looks healthy enough.
:S
Tim what kind of motor got sacrificed in the pics? Total destruction, OUCH
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Jeff.Saunders
It's when you are putting load on the engine for sustained periods when it can turn into a terminal problem.
Z1 Ent on Facebook,
- KZ250LTD
'83 honda xl600, big thumper, big boom
As Jeff said, it was jetted a little lean from the factory, I was just pushing it too hard for too long and it also had a few leaky gaskets = perfect storm. Went from 75mph to nothing in a very short period of time :blink:
79 KZ1000ST
Past:
Many.
- JR
- Thank you received: 449
.........The bike is running great now especially considering how it ran when I first got it. What a huge improvement by just cleaning the carbs/jets and giving the bike a carb sync. No more having to run with the choke on, no more stalls at idle, just smooth running, both on street and freeway. Too bad it is getting a bit too cold out to ride .................quote]
Thats great news sakiguy. I have watched your posts here over the past few weeks and with each one you made progress. It must give you a great feeling of satisfaction that you learned this stuff and made the bike work and run the way it should.
Well done:)
