where to get metric O-rings
- GregZ
19 Dec 2009 05:52
Where to get O-rings for the inlet "T" fittings on 28mm z1 carbs
thanks in advance
thanks in advance
- JMKZHI
Re: where to get metric O-rings
19 Dec 2009 06:50 - 21 Jan 2010 07:20
Not sure if this will be any help....
While looking around The GS Resources webiste, I stumbled across a guy who sells o-ring kits for old bikes, but I don't know if he has what you need. Cycle O-rings.com . I've never purchased anything from him, but I'm pretty sure he's legitimate.
HarborFreight & other places sell metric nitrile o-ring kits, but I'd guess that they don't have the needed size.
Last edit: 21 Jan 2010 07:20 by JMKZHI.
- Mcdroid
- Gone Kwackers
19 Dec 2009 07:10
If you do find a source, try to get Viton o-rings as they are resistant to the reformulated 10% ethanol gasoline.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- roy-b-boy-b
19 Dec 2009 07:36
Harbor Freight is where i got mine. They have a two diffrent sets at the store here. About 10 bucks.
- Mcdroid
- Gone Kwackers
19 Dec 2009 09:13
Greg...have you checked
www.kawasaki.com
to see if the o-rings are still active...they have much still available, particularly for some of the older carb parts (I ordered two sets of o-rings for both my VM26 carb sets from Kawasaki not too long ago...through Jeff, of course!).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TeK9iNe
- What did you do!?!
19 Dec 2009 09:26
Mcdroid wrote:
Thats good advise!
Noted...
Thats good advise!
Noted...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- loudhvx
19 Dec 2009 10:04
Mcdroid wrote:
+1 on that!
This place will let you buy single orings and they have some marked by dimension. They don't have a big selection, but might have what you need.
www.crc2onlinecatalog.com/gl_carb_parts.htm
+1 on that!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Martynbiker
- 1993 KZ1000P
21 Dec 2009 22:10
These people are GREAT to deal with,
Valley Seal Co Inc
Address: 6430 Variel Ave Suite 106
Woodland Hills, CA,
91367-2559
Business Activity: Manufacturer / Distributor
Phone: 818-883-3505
Fax: 818-883-0106
Website: www.valleyseal.com
Valley Seal Co Inc
Woodland Hills, CA,
91367-2559
Phone: 818-883-3505
Fax: 818-883-0106
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
- stardon
22 Dec 2009 15:28
Try McMaster Carr. They have all kinds of O-Rings and information about which ones will suit your needs, and their prices are very reasonable.
- gershom
29 Dec 2009 14:49
Parts Unlimited sells them through dealers.
Part number 2402-0107....$30 for 32 different sizes and a nice case.
I've used these for all kinds of applications. They seem to hold up well with gasoline and oil.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
- almarconi
30 Dec 2009 06:52
McMaster Carr sells an assortment of metric o-rings in a box for about $20.
I've bought o-rings for my gs750 from cycleorings.com , the kit he sells is for the mikuni CV series of carbs, I believe he also has a kit for VM's. Robert is a straight up guy to deal with.
I needed o-rings when I rebuilt the Keihins on my KZ and ended up using the ones from McMaster Carr.
1981 KZ550C LTD (SOLD)
1980 GS750L
1982 KZ750N1 Spectre (New Project)
1980 GS750L
- Online
04 Jan 2010 19:08
Robert Barr of cycleorings.com makes his kit from Buna-N O-rings. There are literally hundreds of GS Suzuki guys running around with these O-rings with excellent results. I've bought both Buna-N and viton O-rings from McMaster-Carr in assembling my own O-ring kits including a set for VM29's that a lot of guys have been using with good results. Buna-N is fine although if you plan on keeping your bike forever, I'd go with viton just for that extra piece of mind.
