- Thank you received: 88
Another easy jetting question
- GregZ
11 Dec 2009 06:15 #338482
by GregZ
Another easy jetting question was created by GregZ
Just finished complete top end on 73 Z1 motor. New guides ,seals complete valve job. Cyl. got minor hone new rings.
Stock 73 carbs 112.5 mains,20 pilots, 3 clip and Stock airbox.
Only change from stock is either a 4-1 yoshimura with baffle or a new Kerker.
Once everything is together I don't want to mess with anything
Should I richin the main jet one to 115? or 117.5?
thanks in advance
thanks in advance
- Kawickrice
- Thank you received: 18
11 Dec 2009 06:48 #338487
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Another easy jetting question
I could be wrong here but I am of the understanding that for each mod (pipe,pods, etc) go up 2 sizes for a ballpark starting point.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 Dec 2009 07:33 #338502
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Another easy jetting question
1 size up should be ok, but 2 might be required depending on some conditions. You will have to swap them and see...
You will have to add some more fuel to the pilot circuit however (via air/fuel screws), to prevent popping on decel.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- GregZ
11 Dec 2009 17:35 #338571
by GregZ
Replied by GregZ on topic Another easy jetting question
two it is. 117.5's maybe lean out later if required
cheers
gregz
cheers
gregz
- davel
11 Dec 2009 17:44 #338573
by davel
Replied by davel on topic Another easy jetting question
GregZ wrote:
Famous last words. If I had a nickle for every time I told myself that...Once everything is together I don't want to mess with anything
- GregZ
12 Dec 2009 05:05 #338593
by GregZ
I agree wishful thinking
