- Thank you received: 2098
KZ650 jetting woes
11 Dec 2009 13:21 - 11 Dec 2009 13:34 #338539
by Patton
Replied by Patton on topic KZ650 jetting woes
The idea is to get the vacuums on all four carbs as even as possible. Ideally, all with same number.
FSM specs for the large Kaw fours is from 20~28 cm Hg, with less than 2 cm Hg difference between any two cylinders.
Good Luck!
Good Luck!
Last edit: 11 Dec 2009 13:34 by Patton.
- seanof30306
12 May 2010 16:12 #367531
by seanof30306
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
Replied by seanof30306 on topic KZ650 jetting woes
An update:
Have the bike back running (although still fighting electrical problems)
The carbs are right for the first time since I've had it. We were never able to get the carbs to synch properly before, they're perfect at last. For the first time, there's none of that drive chain noise associated with unsynched carbs.
It rides perfectly, running perfectly and smoothly from idle up to redline in every gear.
What's odd is, we put the stock jets back in, so despite having pods and a 4-1 header, there are no problems.
It's a little light on power, which I think may be caused by a semi-lean condition, but there's not the slightest bit of popping or backfiring, even at 10,000 rpm.
Once we get the electrical problems solved, I'll do some plug chops and find out where I'm at, but unless it's dangerously lean, I doubt I'll mess with the jetting. Economy is more important to me than power, so a little lean isn't a problem for me.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
