'73 H1-D starter jet
- koob
07 Dec 2009 09:33 #337921
by koob
'73 H1-D starter jet was created by koob
Hi , new here, need some info. for the VM28SC mikuni carb.'s on this bike that I can't find anywhere. In trying to clean the crud out the carbs I finally resorted to spinning a drill bit in my fingers to clear the starter fuel galley in the floar bowl. Later, I sadly found out there's a jet in this passage, which I have to suspect is now enlarged, but since I did all three I don't know for sure. Research shows these jets are a press-in and are sized and numbered for each particular application, but I haven't been able to find out what mine ought to be. Does anybody have this info, or would you be willing to measure yours ( I'm thinking a snug fit with a drill bit would be awful close) and tell me the proper dia. of the jet hole? I figure if mine are hugely oversize I can try making brass plugs with a correctly sized hole & press them into the starter fuel galley inlet hole at the bottom of the float chamber in the float bowl. Sound workable? I'd like to be able to let the bike idle & warm up a bit with the starter open (works well with my other 2-strokes), hence my concern with having the proper sized starter jets in place. Thanks for the help!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Dec 2009 10:54 - 07 Dec 2009 10:55 #337934
by TeK9iNe
I wish I could help further...
I'll keep looking.
Maybe just fire it up and see what happens...
Good Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic '73 H1-D starter jet
I'll keep looking.
Good Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 07 Dec 2009 10:55 by TeK9iNe.
