- Thank you received: 3
Which dynojet kit?
- 9am53
- homebrew, and some bbq
04 Dec 2009 08:54 #337453
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Which dynojet kit? was created by 9am53
I am buying some pods for my 1982 kz1000 LTD and am having a little trouble choosing which dynojet kit to get.
www.dynojet.com/jetkits/motorcycle/kawasaki.aspx
If you scroll down and see the 81-83 LTD/CSR1000 there is only one choice, BUT I have a set of J cams in it, so I think the ELR/J kits would apply right? Secondly, I have a choice between stage 1 and 3, if I have stock J cams, pods, and a 4-1 would I be better suited with the stage 1? The only difference seems to be the main jet...
Thanks for answering my played out question!
'84 GPz900r
'71 CB350
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 Dec 2009 10:54 - 04 Dec 2009 10:56 #337476
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Which dynojet kit?
The LTD/CSR 1000 kit, is for the BS34's that you have, and will work fine with the J cams.
Go with the stage 3 kit, as it covers pods either with or without a highflow exhaust.
I believe the part number is 2301 ...
Cheers!
Good luck.
Cheers!
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 04 Dec 2009 10:56 by TeK9iNe.
- 9am53
04 Dec 2009 11:00 #337479
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic Which dynojet kit?
But the J and ELR have BS34's as well don't they? and would the kit for the J or ELR not complement my cams better than the LTD kit since I have J cams now?
'84 GPz900r
'71 CB350
- TeK9iNe
04 Dec 2009 11:36 #337491
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
yes, the J had BS34's, and the ELR as well I believe.
And yes, you are correct, I thought something else for a moment there... :blink:
The ELR/J kit would be better suited for your application as I realise your refering to the bike, not the motor :laugh:
The stage 3 kit would be best, again for your new setup. The stage 1 kit only covers a drop in filter, which would not be enough main for your pods.
Cheers :laugh:
Cheers :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
04 Dec 2009 11:39 #337492
by 9am53
'84 GPz900r
'71 CB350
dope, thanks man...
'84 GPz900r
'71 CB350
- TeK9iNe
04 Dec 2009 11:53 #337498
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
No problem! I'm at least somewhat usefull, half awake. :laugh:
Night shift... Bah!
Night shift... Bah!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
