Broken float.
- knisely
04 Dec 2009 05:48 #337438
by knisely
Broken float. was created by knisely
I've been rebuilding the carbs on my 1978 KZ650. I somehow managed to knock one of the floats on the edge of my bench and broke one of the foam pieces off. Is there anywhere I can find new floats for my bike? I've been looking around but havent been able to find any specific to my '78 650.
- JMKZHI
- Thank you received: 48
04 Dec 2009 08:14 #337449
by JMKZHI
Replied by JMKZHI on topic Broken float.
Motorcyle salvage yard or ebbaayy. You may have to buy a rack of carbs - maybe you'll get lucky & find something cheap. I would guess that the VM24 carbs all use the same floats - check the cross-reference at Kawasaki.com.
- loudhvx
- Thank you received: 1616
04 Dec 2009 10:15 #337469
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Broken float.
Like JMKZH1 syas, you'd probably have to get a whole rack. You may find a beat up set for $20 if you're lucky, but why don't you edit the title of this thread to say "needed: 1 float for 650 carbs". Someone around here has got to have a set laying around for parts.
1981 KZ550 D1 gpz.
Other links.
- knisely
04 Dec 2009 11:17 #337486
by knisely
Replied by knisely on topic Broken float.
I did find this web site
www.carbkitscapital.com/carb_kit_list_mo...Kawasaki&model=KZ650
They have floats for an '82 650H2. Does anyone know it these floats would work in my VM24ss Carbs?
- JMKZHI
04 Dec 2009 14:53 #337517
by JMKZHI
No. The 82-83 CSRs came w BS32 carbs.
Go to ebbaayy & search for KZ650 float or KZ650 carbs or something like that. You should find all sorts of options - maybe not all cheap but some options non-the-less. Also, sometimes searching the part number yields a result or two.
- anarki650
- Thank you received: 5
04 Dec 2009 15:36 #337522
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Broken float.
I've got a float. Sent you a pm.
09 Kawasaki ER6n
Omaha NE
