Carb ID
- JakeB
03 Dec 2009 12:06 #337264
by JakeB
1978 Z1-R
Replied by JakeB on topic Carb ID
s3steve wrote:
Mikuni has the VM manual here on their website. I believe that is also in the filebase section on this site. It doesn't mention the VM28SS but the tuning info should apply.
If you're looking for part numbers there are diagrams here. Just click "Parts Diagrams" under "Vehicle Information".
Hope that helps,
JakeB
Anybody know where I can download a manual on these carbs or maybe a Z1R specific website?
Hope that helps,
JakeB
1978 Z1-R
- Kawboy74
- Thank you received: 52
03 Dec 2009 19:07 #337361
by Kawboy74
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
Replied by Kawboy74 on topic Carb ID
If you are willing to take a chance, pull out the slides and check the numbers etched into the needles. If you have a Haynes or a factory manual you can reference what carbs those needles apply to. When pulling carbs apart, check to see if it looks like somebody has previously had them apart (yellow paint on nuts etc.) and that way you may be lucky and have a non-molested set of carbs and proper I.D. of same. Good luck:)
- s3steve
- Thank you received: 1
04 Dec 2009 04:43 #337433
by s3steve
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
Replied by s3steve on topic Carb ID
roy-b-boy-b wrote:
I had a quick look last night and didn't see any numbers on the flange.
Kawboy74 these carbs have definitely been apart more the once. The screws that hold the carbs to the flange show some wear. The bike had K&N pod filters and a Kerker 4 into 1 pipe so I would assume it's been re-jetted but I'll find out over the weekend when I dig in to them a little more.
I think I'm going to pass on the "lemon juice" cleaning method after seeing the results. They end up looking very dull from what I've seen.
I've had great results with Kleen-Flo carb cleaner in the past. It's a dip type method but you have to strip the carbs and remove all the rubber parts. Plus it's about $70 a gallon.
At this point I think I'll just strip the brass, soak it, spray the bodies with a can or two of the aerosol type carb cleaner and a small brush and rags and blow it out with compressed air.
Are there any I.D. numbers on the flange near the choke handle where the carbs slip into the boots? Roy
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
- rstnick
- Thank you received: 377
04 Dec 2009 08:45 - 04 Dec 2009 08:47 #337450
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Carb ID
There's a cheap soda blaster method post on here somewhere.
If you already have a compresser, for about $5~$10 you can make a soda blaster.
Here's a link:
www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
Here's a link:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 04 Dec 2009 08:47 by rstnick.
- s3steve
04 Dec 2009 09:29 #337460
by s3steve
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
Yeah I saw that, it might be worth a try. The results look pretty impressive.
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
