Plug chop?
- sbulla
- 1980 KZ1000 LTD
30 Nov 2009 07:34 #336677
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Plug chop? was created by sbulla
Just how long of a run does it take at a certain throttle setting to get a good plug reading when doing a plug chop to determine jetting?
I ask this as the road near my house is kinda busy and full throttle runs gets me on top of another car really fast! Just wondering how long it takes to "color" the plug enough to get an accurate read.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- timebomb33
- Thank you received: 10
30 Nov 2009 07:51 - 30 Nov 2009 07:53 #336678
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Plug chop?
with fresh plugs at least a 1/4 of a mile but plugs chops aren't really all that accurate anymore with all the different additives that are in the fuels nowadays you can get fooled the best way to get your jetting right is to invest in at least 3 dyno runs with an air fuel ratio meter plugged in to the exhaust if your interested in mileage try for around 14.5/1 a/f mixture if you want power go for around 13.5 to 1. it really not worth getting tickets or crashing in to someone to check your jetting. spend a bit at a good dyno place up front and it will be worth it. look for a shop that has a dynojet 250 dyno with the econonamy like it is and the time of year you probably can get a deal. make a run if you need to make changes then your in a nice warm shop already make your changes then give it another pull. by the way plug chops can be done at any throttle position but most times you use them to check main jets so wide open throttle is needed.
Last edit: 30 Nov 2009 07:53 by timebomb33.
- sbulla
- 1980 KZ1000 LTD
30 Nov 2009 10:41 #336703
by sbulla
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
Replied by sbulla on topic Plug chop?
Thanks, I've been out checking my pilot jetting and need to change it so, I thought I'd try to see what the main was doing before I pulled the carbs again and was wondering how much of a run I'd have to get.
Would like to have a dyno around! About how much is the normal charge for dyno time?
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
