- Thank you received: 2237
GPz to ZRX carbs
28 Nov 2009 19:44 #336393
by TexasKZ
GPz to ZRX carbs was created by TexasKZ
Does anybody know if the GPz 1100 (early 80s version) and the ZRX 1100 have the same carb spacing?
- kano
- Not Another Bloody Limey!
28 Nov 2009 20:20 #336401
by kano
Replied by kano on topic GPz to ZRX carbs
no they don't.
- JonnyC
02 Dec 2009 21:26 #337182
by JonnyC
1977 KZ650C
Replied by JonnyC on topic GPz to ZRX carbs
can an 81 gpz1100 be converted to carb? if so how? some guy is selling one for 200 bucks, its fairly clean and runs just some tiny issues
1977 KZ650C
- kano
02 Dec 2009 23:29 #337190
by kano
yes it can.
use bs 34's and block injector ports with bolts,
iv'e done the same on my motor.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
03 Dec 2009 03:39 #337194
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic GPz to ZRX carbs
JonnyC wrote:
Another issue you will address if you convert to carbs (particularly BS34's) is that the stock petcock on a stock KZ1100B1 tank will have to be relocated/replaced as the original FI occupies less space than do the replacement carbs. The stock petcock will not clear the carbs. Additionally, the opening for the pressure relief valve on the underside of the fuel tank (necessary for the FI to function) will have to be capped.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JonnyC
