carb questions for my kz400
- gigolojoe
26 Nov 2009 19:52 #336097
by gigolojoe
carb questions for my kz400 was created by gigolojoe
Hi,
Couple questions from a newbie.
My kz400 carbs each have 3 hoses. One on the top, one in the side and one on the bottom. I know the top ones go to the gas tank, but where do the other 2 connect to???
Where can I get a rebuild kit or a set of new carbs?
Thanks
Thanks
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- Thank you received: 20
26 Nov 2009 20:04 #336099
by newOld_kz1000
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Replied by newOld_kz1000 on topic carb questions for my kz400
gigolojoe wrote:
Seach ebay for the following: kz400 carb kit
and up will come results with kits.
The bottom hose is for overflow. If for whatever
reason your carb float bowls fill up with too much gas, that bottom outlet is there to try and stop raw gas from flowing into the engine's intakes then down into the crankcase.
You can force the float bowls to keep filling up
by putting the petcock on 'Prime' if you want to
see this overflow working. Or, if for some reason
your float sticks and/or the float's valve ('needle valve') goes south and the gas keeps comin in, same overflow can happen -- TO BE AVOIDED.
The top hose is a breather to vent fumes and usually
a rubber hose routes toward the rear of the bike for those (or into an emissions cannister doohickey on later bikes).
Good luck there, if it's your 1st bike, WATCH OUT FER
THE LAYDIES they love fellers on sickles, you'll have
enough hot yun laydies to never be lonely agin!!
Hi,
Thanks
