- Thank you received: 2
popping 810 (bs34s)
- pburnhamb
25 Nov 2009 08:23 #335853
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
popping 810 (bs34s) was created by pburnhamb
After the 810 build the bike rode like a dream (was a 650), anyway, now that the torture is over breaking in the pistons, i am starting to get on it a bit more and i notice that she pops quite a bit when i let off the throttle at 5000+RPM & 3/4+ throttle. She has a set of BS34 carbs with pods and 40/140 jets. They were super clean (my doing) when i first woke the beast after the rebuild and there was no popping at all.
I am of course going to clean them and then clean them again tonite. If the popping persists what should i look to do with the main jets? or any other ideas?
I think i didnt notice this before because i was breaking the pistons in as they say to (wiseco) not 3/4-full throttle.which by the way is extremely painfull!!
Thank you for any and all help.
-patrick-
-patrick-
1976 kz900
1977 xs650
- TeK9iNe
- What did you do!?!
- Thank you received: 28
25 Nov 2009 09:39 - 25 Nov 2009 09:44 #335859
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic popping 810 (bs34s)
The popping your getting is normal for a sudden lean condition that occurs at high rpm when the throttle (is released) returns to the pilot circuit.
You can turn the pilot mixture screws out (on top front of BS34s') 1/4 turn at a time (out) to add more fuel mixture into the pilot circuit. This is ok up to a max of about 4 turns.
This normally works, but if not, pilots will have to be changed to next larger size.
Cheers, good luck.
PS. Has the bike been properly re-jetted? Have you used different jet increments? With that setup, a larger main and raised needles may be required.
Cheers, good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 25 Nov 2009 09:44 by TeK9iNe.
- timebomb33
- Thank you received: 10
25 Nov 2009 10:28 #335867
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic popping 810 (bs34s)
like tek9 said turn out your fuel screws abit at a time equally on all 4 carb's that should get rid of your problem
- larrycavan
- Visitor
25 Nov 2009 15:39 #335911
by larrycavan
Replied by larrycavan on topic popping 810 (bs34s)
Air leaks in the exhaust can make them pop as well. Sometimes collectors don't fit properly.
- bountyhunter
- Thank you received: 337
25 Nov 2009 16:31 - 25 Nov 2009 16:32 #335924
by bountyhunter
Replied by bountyhunter on topic popping 810 (bs34s)
A little popping is normal, if excessive you should try larger pilot jets.
If you have header exhaust leaks at the exhaust port (gaskets not sealed) the popping will sound WAYYYYY louder like firecrackers.
been there, heard that....:laugh:
Last edit: 25 Nov 2009 16:32 by bountyhunter.
