what aftermarket carbs for kz650
- KawCustoms
24 Nov 2009 13:36 #335659
by KawCustoms
what aftermarket carbs for kz650 was created by KawCustoms
Ive been having a few issues with my Kz650 carbs and was wondering if anyone knew of some good aftermarket carbs or what I could go with
- rstnick
- Thank you received: 377
24 Nov 2009 13:56 #335661
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic what aftermarket carbs for kz650
900/1000 26mm & 28mm carbs will fit with a few modifications, as well as 29mm smoothbores $$$.
Maybe some flatslides, but we'll have to let someone who knows confirm that.
BS34 too I believe.
What's wrong with the carbs you have?
BS34 too I believe.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- KawCustoms
24 Nov 2009 15:11 #335669
by KawCustoms
Replied by KawCustoms on topic what aftermarket carbs for kz650
last owner used a dremel when he cleaned em. I just had them rebuilt and they wont pull vacuum, I was told it would be etter to find new ones... I just cant find any of the 29mm
- Thank you received: 2829
24 Nov 2009 15:43 #335670
by 650ed
Replied by 650ed on topic what aftermarket carbs for kz650
I don't know what you mean by "they won't pull vacuum." What year and model KZ650 do you have? Different years/models had different carbs. Ed
- JMKZHI
- Thank you received: 48
24 Nov 2009 17:49 #335696
by JMKZHI
Replied by JMKZHI on topic what aftermarket carbs for kz650
I have a set of VM24 carburetors w accelerator pump listed in the KZR classified section. They're in very good condition.
- KawCustoms
24 Nov 2009 18:40 #335730
by KawCustoms
sweet can you post a link
- JMKZHI
24 Nov 2009 20:56 - 25 Nov 2009 15:44 #335778
by JMKZHI
Here you go:
KZ650 VM24 carburetors w accelerator pump
Edit: you have to be logged in to see the KZR classifieds & the ad I linked.
Last edit: 25 Nov 2009 15:44 by JMKZHI.
- spudbudy
- Kick it like you mean it
- Thank you received: 1
22 Jan 2010 16:47 #343998
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Replied by spudbudy on topic what aftermarket carbs for kz650
go with a set of vm26's from a suzuki gs750 and you won't regret it big difference all good.
- Bluemeanie
- Thank you received: 14
23 Jan 2010 06:21 #344044
by Bluemeanie
Replied by Bluemeanie on topic what aftermarket carbs for kz650
KawCustoms wrote:
Super ultra rare for sure! Last set on ebay went for $445!
I just I just cant find any of the 29mm
