sync carbs 10 in vac
- sr man
- Hawk
23 Nov 2009 08:14 - 23 Nov 2009 10:48 #335354
by sr man
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
sync carbs 10 in vac was created by sr man
1978 kz650 sr
1980 E1 LTD moter
Carburetor Synchronizer carb sync Gauge
When I try to sync my carbs I can onley get 10 in of vac and thats having them all the same. I used another gage to check it for acc and it was correct. Now if I tinker with them I can get 3 up to 18in and one always is about 6in of vac no matter what combo its always will have one with low. Meaning its not the same carb everytime with the 6in of vac.
Is 10in of vac acceptable of do I have a probablm. The bike idles great weak off line put runs great otherwise
1980 E1 LTD moter
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
Last edit: 23 Nov 2009 10:48 by sr man. Reason: more info
- bill_wilcox100
- Thank you received: 5
23 Nov 2009 08:44 #335359
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic sync carbs 10 in vac
Hi SR Man,
What bike are we talking about?
What vacuum measurement tool are we talking about?
Best of success
Bill
PS
Could you add your year, model and location to your signature? It helps get the best responses and it's considered real friendly too.
Bill
Best of success
Bill
PS
Bill
Upgrades:
Montreal, Canada
- Qdude
- It is all good.
- Thank you received: 1
23 Nov 2009 08:45 #335360
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic sync carbs 10 in vac
There are many factors that can cause differences in the readings.
You might also have a vacuum leak from a hole or crack in casings or gasket, missing parts or loose fasteners etc..
When was the last time the carbs were rebuilt/cleaned?
Have you taken the engine apart recently?
What is the history of the bike that would offer more clues?
77 KZ 650 C1.
77 KZ 650 C1.
- sr man
- Hawk
23 Nov 2009 10:47 #335385
by sr man
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
Replied by sr man on topic sync carbs 10 in vac
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- timebomb33
- Thank you received: 10
23 Nov 2009 11:07 #335386
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic sync carbs 10 in vac
what r.pm are you doing the carb sync at and as other people have also said look for an air leak.
- sr man
- Hawk
23 Nov 2009 11:24 #335390
by sr man
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
1000 to 1500 it varies
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- flht1997
- Thank you received: 2
23 Nov 2009 12:18 #335395
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic sync carbs 10 in vac
i'd say 10 is fine as long as they are even. the last sync on my 650 with gauges like those, mine were reading 10 psi also.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
