What to Fix on Vacuum Prob?
- gravityoutlaw
The bike a 1980 Z500 runs well through the gears until you want to cruise on the motorway then it starts to hold back like fuel starvation. I've run the test as per forum and the bike runs perfect with fuel cap open and tap on prime, but I can't find on the forum what parts to replace for the fix!
E.g do I need to rebuild petcock or fuel cap or both. Or is it just to replace diaphragm in petcock.
Can anyone please guide me
Cheers
Colin
- Bluemeanie
- Thank you received: 14
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- gravityoutlaw
Cheers
Colin
- Qdude
- It is all good.
Took me about a fortnight to finally suss it out. Good hunting!!
77 KZ 650 C1.
77 KZ 650 C1.
- MFolks
- Thank you received: 540
- Bluemeanie
The problem is still there with tap on "on" and cap opened, I could here the cap hissing when problem started after I got back from work! It might be a mixture of both cap & tap. Would it pay to get a new diaphragm for the petcock and a inline filter + check petcock for any restrictions?
Cheers
Colin
If your diaphram was bad it would be spraying fuel as one side has fuel and the other side has vacuum. Where do you have vacuum hooked up to?
- Thank you received: 2098
This entails removal of the petcock from the fuel tank, and complete disassembly of the petcock.
Correct reassembly is of course also required.
Fuel flow through vacuum operated petcock may be tested with engine not running by detaching the fuel line from the petcock, turn vacuum operated petcock to ON or RES (not PRI), detach vacuum hose from carb, use a syringe to supply vacuum to hose, and watch for fuel flow from petcock nipple.
On a vacuum operated petcock in ON or RES position (not PRI), the fuel flow is blocked by operation of a diaphram/o-ring/spring until vacuum is applied (which vacuum usually comes from a running engine).
Do you have for reference a parts diagram of the petcock?
Good Luck!
[Click on image to enhance view]
Good Luck!
- gravityoutlaw
Cheers for all your inputs
Colin
- Bluemeanie
