- Thank you received: 2
Idle Adjusting Screw Setting
- sakiguy
22 Nov 2009 17:00 - 22 Nov 2009 17:00 #335244
by sakiguy
1983 KZ750 N2 Shaft
Idle Adjusting Screw Setting was created by sakiguy
Is there a Standard setting for this? I lost all track of it when I pulled the carbs for cleaning. Doesn't state it in the manual. I'm guessing there is. Carbs are Keihin CV34.
1983 KZ750 N2 Shaft
Last edit: 22 Nov 2009 17:00 by sakiguy.
- kz750rider
22 Nov 2009 17:07 #335247
by kz750rider
Replied by kz750rider on topic Idle Adjusting Screw Setting
All I go on is the manual which says 1050 or thereabouts.
- sakiguy
22 Nov 2009 17:13 #335248
by sakiguy
1983 KZ750 N2 Shaft
Replied by sakiguy on topic Idle Adjusting Screw Setting
Yah, I see that in the manual, but I was thinking that maybe there are a certain number of turns out as well...because I'm pretty sure it's way off the mark. I was thinking there is a way to get the setting in the ball park area befoer I put them back on, then do the fine adjustment once I get it running.
1983 KZ750 N2 Shaft
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Nov 2009 16:33 #335676
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Idle Adjusting Screw Setting
A good ballpark setting is 1&1/2 turns out from lightly seated.
When tuning pilot screws with engine running, turn all 4 in/out the same till highest idle, then tune individually for highest idle in small increments.
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JR
- Thank you received: 449
24 Nov 2009 18:06 #335717
by JR
Replied by JR on topic Idle Adjusting Screw Setting
sakiguy wrote:
If you're talking about that big black knobbed screw between and below carbs # 2 and 3 then there is'nt really a factory setting. If you did'nt mess with it when you had the carbs off then it will be in the ballpark when you put the carbs back on. If you did take it apart then set in about the middle of the adjustment range, start the bike and let it really warm up well before fine tuning. I like to have the idle speed at about 1200rpm.
