- Thank you received: 88
Plastic airbox Softener
- GregZ
20 Nov 2009 08:11 #334837
by GregZ
Plastic airbox Softener was created by GregZ
I have a Z1 airbox that is a little stiff. Is there anything on the market that soften it up.
- Thank you received: 2237
20 Nov 2009 19:44 #334932
by TexasKZ
Replied by TexasKZ on topic Plastic airbox Softener
A propane torch. :laugh:
If you mean the boots that connect the box to the carbs, then a pan of hot water may help, but new boots are best.
- otakar
20 Nov 2009 20:00 #334940
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Plastic airbox Softener
TexasKZ wrote:
I think he has a Z1 which had the one piece box assembly. There were no boots. There is no way to soften the plastic permanently. You can soak it in something like Xylene to allow the plastic to "puff" up temporarily. But it may harden it even more in the long run. The best thing to do, is to warm the plastic with a hair dryer while you are mounting it.A propane torch. :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
