- Thank you received: 1
idle speed
- bullitt
20 Nov 2009 04:56 #334804
by bullitt
idle speed was created by bullitt
how fast should a z750e idle
- Thank you received: 2829
20 Nov 2009 08:41 #334844
by 650ed
Replied by 650ed on topic idle speed
I keep my KZ650 idle at 1000 RPM. It will idle lower (down to about 700 RPM) but if you idle it too low you may not be supplying enough oil pressure. Ed
- bullitt
21 Nov 2009 03:16 #334968
by bullitt
Replied by bullitt on topic idle speed
thanks my idles at 11oo any lower sounds horrible and lumpy
i thought this might be to fast cheers
- Thank you received: 2098
21 Nov 2009 05:49 - 21 Nov 2009 06:04 #334981
by Patton
Replied by Patton on topic idle speed
The oem tacks are often less accurate at low rpm.
A good tune-up and carb sync should produce a smooth idle.
On the large fours, the idle is too low when the engine begins sounding like it's digesting nails.
For best idle, would rely more on feel and sound, and less on the tach reading.
Good Luck!
Good Luck!
Last edit: 21 Nov 2009 06:04 by Patton.
- TeK9iNe
- What did you do!?!
21 Nov 2009 10:31 #335049
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic idle speed
Check Check Check that cam chain tensioner!
When the cam chain gets a little loose, it starts to get loud and clacky at lower rpms.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
