- Thank you received: 1
idle problem
- bullitt
18 Nov 2009 10:43 #334472
by bullitt
idle problem was created by bullitt
hi guys long time no type my bike idles
lovely with choke half on take choke off sounds
camyare my carbs out of balance.
my bike is a kz750e pod filters new jets on
she sounds and runs lovely when you open the throttle
any ideas cheers dave
- bountyhunter
- Thank you received: 337
18 Nov 2009 11:36 #334475
by bountyhunter
Replied by bountyhunter on topic idle problem
Could be a vacuum leak? Maybe they need the throttle plates synchronized (balanced).
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Nov 2009 11:55 #335060
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic idle problem
I'd guess the same... air leak, or bad carb sync.
Valve lash is deffinately a necessary check.
Compression could be down...
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
