where do all these hoses go?
- 55fbomb
15 Nov 2009 11:39 #333878
by 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
where do all these hoses go? was created by 55fbomb
i tore the air box off my 78kz650 and put pods on it. can someone tell me where the hoses go that come off of the (i think) 2 and 4 carbs from the carb body, they were not hooked up to anything to begin with. also where are you guys with pods routing that tube the was hooked to the bottom of the air box that comes from the top of the transmission? thanks in advance, tyler.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- kano
- Not Another Bloody Limey!
15 Nov 2009 11:47 #333880
by kano
Replied by kano on topic where do all these hoses go?
the tubes on the bottom of each carb are for over flow, let them route down below engine,
vent in crank case attach a long tube and let it vent.
- 55fbomb
15 Nov 2009 12:54 #333889
by 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
Replied by 55fbomb on topic where do all these hoses go?
ok, the tubes for the overflow are history, the tubes i mean come out of the body of the carbs, but only on 2 and 4 and they were just layin on top the airbox, they look like vacuum hoses but i cant imagine where they go and cant figure it out, as for the vent info thanks thats all i needed to here. i give you guys a lot of credit because these KZs have been a real bitch so far. thanks again kano, now if i can figure out these two hoses off the carb bodies i will be in good shape.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- kano
15 Nov 2009 13:00 #333891
by kano
there should be 4 tubes 1 on the underneath of each carb fuel bowl,
these are just in case the float needles stick and the fuel will vent threw tubes to the ground.
- anarki650
- Thank you received: 5
15 Nov 2009 13:33 #333895
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic where do all these hoses go?
kano wrote:
those other two hoses are atmospheric vents and don't hook up to anyhing. I've alwYs run mine without any hoses hooked up to those ports and never had any issues. You prob want to put overflow hoses on the bottom nipples though, if nothing else they'll keep fuel off your feet if your carbs overflow
09 Kawasaki ER6n
Omaha NE
- JMKZHI
- Thank you received: 48
15 Nov 2009 13:50 #333897
by JMKZHI
Replied by JMKZHI on topic where do all these hoses go?
Vent tubing might help to keep water & debris out of the carbs. The overflow tubing is there to direct fuel away from a hot engine in the event that there's a fuel supply malfunction or if you dump the bike.
- 55fbomb
15 Nov 2009 15:04 #333925
by 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
the atmosphere vents make sense, i just wasnt sure, thank you. as for the overflow tubes i ripped them off so if one of my floats stick i know which one it is, instead of chasing a maze of tubes around. might put them back on once everything is sorted out but for now messin around in the garage i dont see the need for them, although some good pionts were brought up about why they are there. thanks for all your help, im sure im gonna have lots more questions, LOL.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- rstnick
- Thank you received: 377
16 Nov 2009 06:33 - 16 Nov 2009 06:36 #334056
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic where do all these hoses go?
You already got your answer, but here's a picture as well.
A simialr question was asked at forums.kz650.info/index.php?PHPSESSID=f7...63193dd&topic=1893.0
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 16 Nov 2009 06:36 by rstnick.
