- Thank you received: 20
I done broked my pilot adjusting pointy end!!!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
And since it's a brass screw, I guess (?) the pointy tip of it broke off and WAS STUCK in the little hole there in the mouth of the carb on the engine side. I had the Pilot screw completely removed and yet its little brass tip was still visible in the mouth of the carb. Sh*t!!! Visions of searching on eBay for a used bank of kz1000 carbs roared through my tiny little pea brain.
Luckily, the little pointy brass tip came completely out of the carb when I tapped on it.
But now my Pilot screw is missing its pointy tip.
WHAT WILL THIS DO TO THE IDLE RUNNING OF THE MOTOR?
(ps. reason I screwed in the Pilot adjusting screw was to first seat it in the 'all the way closed' position then back it out the standard 2 1/2 turns.)
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- newOld_kz1000
See, I don't want to have to order a new pilot adjusting screw. See the picture of my carbs during the cleaning below -- in the picture I'm holding the Pilot Adjusting Screw with my needlenose plier.
This is *before* I broke the pointy tip off.
I want to continue to use this Pilot Adjusting Screw despite its broken tip because--
well, because (1) I'm cheap (2) I already waited a week
to get parts (o-rings) to finish the carb job, I now
have them in my hands, I don't feel like waiting another week for a new Pilot Adjusting Screw, and (3) I'm quite suspicious that my #2 carb will not very much miss that little tip off the Pilot Adjusting Screw.
AM I RIGHT?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- newOld_kz1000
By over-tightening the pilot screw, you have enlarged the hole in the aluminum. This will now totally screw up the adjustment in relationship to the other three carburetors. The needle is no problem. one comes in every carburetor rebuild kit. There are two things you can do; 1) replace that throttle body, 2) adjust each carburetor individually by ear or tach at idle. The second option is much cheaper, but requires some skill, and experience.
I'm sorry for mixing words -- I have edited my post to be consistent.
There is a 'pilot jet' in each carb -- which I'm not talking about at all.
There is, in each carb, a part called:
"16014-018 SCREW,PILOT ADJUSTING"
THAT is what I'm referring too. I corrected my post to be consistent in my verbiage.
I take your point -- I may have to deal with a different adjustment for this carb whose Pilot Adjusting Screw I overtightened.
What should I expect when I start the motor? I mean, should I expect that at idle and the very start of opening the throttle, that this one cylinder won't be firing or something?
- keith1
the broken tip might be your biggest problem, not the fact that you might have bored out the hole it screws into a little....that tip is there for a reason...i m guessing you are gonna have a little difficulty dialing in that one carb...it s gonna be all or nothing as far as
an adjustment.....just my guess....hell, put em back on and see what ya get....i think i have another pilot screw
you can have.....let me know....
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
- Thank you received: 240
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- gane
[img][/img] 1977 KZ1000A1
- newOld_kz1000
Thanks for your encouragement, I think I will put on the carbs, and just be prepared for some challenge to get the one carb so it's not affecting the just-off-idle or the actual idle.
- newOld_kz1000
i knew exactly what you were referring to. The needle only affects the idle nothing else. i believe that on this particular carburetor, this is a fuel screw. If it was on the side it would be an air screw. This means that if you adjust the screw according to the book the engine will be rich at idle.
Okay, thanks for being knowledgeable, I have a question -- I looked high and low in my Kawasaki shop manual (the official one from the manufacturer, not a Clymer) and all I found for adjusting this Pilot Adjustment Screw was on page 47, bottom right:
"...turn in the Pilot screw fully, but not tightly, and then back it out the number of turns counted during disassembly."
Well there's 3 things wrong with that:
1) doesn't even give a rough guidance like "usually 1 1/2 turns out should be sufficient"
2) 'fully but not tightly' sorry there whats the difference (duh the difference is I broke the tip off)
3) 'counted during disassembly' -- what if you're some type of rabid idjit and you *assume* there is a 'rough guide' as in (1) above....so you never bothered to be careful and count the number of turns out and write it down
I vaguely recall about 2 1/2 turns out but not sure.
My question is, do you have a rough starting point for the number of turns out from the 'fully in' position for these Pilot Adjustment screws on stock carbs for this kz1000 '78? Is there somewhere in the kz1000 official shop manual, such as a table or description that I have not stumbled across yet?
