jet size
- donnykoonce
12 Nov 2009 16:45 #333182
by donnykoonce
jet size was created by donnykoonce
I have a 1978 KZ 1000 with a 4 into 1 header and pod filters. What size carb jets do I use?
- PLUMMEN
- Thank you received: 104
12 Nov 2009 17:04 - 12 Nov 2009 17:06 #333193
by PLUMMEN
Replied by PLUMMEN on topic jet size
Last edit: 12 Nov 2009 17:06 by PLUMMEN.
- roy-b-boy-b
- Thank you received: 103
12 Nov 2009 17:06 #333194
by roy-b-boy-b
Replied by roy-b-boy-b on topic jet size
20/120 might work. I run a open header. Roy
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Nov 2009 19:04 #333280
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic jet size
The ones that give you the most power with smooth throttle transitions.
You will probally go thru many sets, just remember: only change one circuit at a time.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
