- Thank you received: 88
Please I.D. these carbs
- GregZ
12 Nov 2009 05:11 #333074
by GregZ
Please I.D. these carbs was created by GregZ
These carbs were on a recent 73 Z1 purchase. The previuos owner had no idea about original 28mm carbs. He took his carbs to a independent bike shop for cleaning and the owner just swapped him for these 26's and then sold the 73 28's on ebay. What an A$$. these carbs were ultrasonic cleaned look good I just don't know what the top plate is for ,never seen that. What are these carbs for ?? they will be eBayed soon
- The Fish
- Thank you received: 6
12 Nov 2009 06:49 #333083
by The Fish
Replied by The Fish on topic Please I.D. these carbs
1976 KZ 900.
The 76 had the "brace" between the carb tops and also has the idle screw mounting plate screws at about 45 degrees.
- savedrider
- 1975 Z1-B 900
- Thank you received: 1
12 Nov 2009 17:38 - 12 Nov 2009 17:39 #333222
by savedrider
Get right or get left! <*{{{><
Replied by savedrider on topic Please I.D. these carbs
Yes, 76 KZ900. I have those carbs (minus the plate). They are actually nice carbs, easy to tune and hold a tune quite well.
Last edit: 12 Nov 2009 17:39 by savedrider.
- Thank you received: 2098
12 Nov 2009 18:31 #333258
by Patton
Replied by Patton on topic Please I.D. these carbs
Imo, 1976 KZ 900 oem carbs are very user friendly.
Good Luck!
Good Luck!
12 Nov 2009 18:38 - 12 Nov 2009 18:38 #333265
by Patton
Last edit: 12 Nov 2009 18:38 by Patton.
- roy-b-boy-b
- Thank you received: 103
13 Nov 2009 04:34 #333348
by roy-b-boy-b
Replied by roy-b-boy-b on topic Please I.D. these carbs
If someone took the carbs off my Z1 he would have been talking to a judge!
On the flange near where the carbs go in the boots there is a number. Where you are holding the carbs. Roy
- bluej58
- Thank you received: 511
14 Nov 2009 16:24 - 14 Nov 2009 16:29 #333686
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Please I.D. these carbs
How would you guys compare the 76 kz900 carbs against a 78 kz1000 set ?
I have a set of kz900's and they seem to be in better shape then the stock ones on my bike. JD
78 KZ1000 A2A
Last edit: 14 Nov 2009 16:29 by bluej58.
- roy-b-boy-b
14 Nov 2009 17:22 - 14 Nov 2009 17:24 #333701
by roy-b-boy-b
The "Z" carbs should be 28mm. Worth a lot of bucks.
The 76 carbs and the 78 set should be a lot alike. Roy
Last edit: 14 Nov 2009 17:24 by roy-b-boy-b.
