installing carbs`
- leitrum
installing carbs`
21 Oct 2005 18:49Please Log in or Create an account to join the conversation.
- savedrider
- 1975 Z1-B 900
Re: installing carbs`
21 Oct 2005 20:13
Or you could buy a couple pod filters and ditch the stock setup...I think your issue is why this happens more often than not.
Have you tried wiping the inside of the tubes with some WD-40 to help them slide on easier?
Get right or get left! <*{{{><
- GargantuChet
21 Oct 2005 21:02
You can buy yourself a set of four new air box boots from
Z1 Enterprises
for around $40.
EDIT: To be clear, yes, they should be pliable. Mine are bad, too, and I'll probably be ordering a set myself next week if I can spare the cash.
Post edited by: GargantuChet, at: 2005/10/22 00:03
- John68
21 Oct 2005 22:29
actually, you would be paying $20 for new boots, because you only require two of them, compared to us inline 4 guy swho need 4 of them. $13, and you get open elements, or filter pods for the bike. I personally like things stock, but for $13, you can't go wrong.
aloha
aloha
- leitrum
22 Oct 2005 04:06
don't know how but i got it in:P she is purrrrrrrrrring on to the next step thx for your help. will be replacing tube, tires, brakes, chain next. any helpful hints on these installs would be welcome. since it took me 3 hours to put back on the carbs
- Wolfman@SparksAmerica
22 Oct 2005 05:14
wheel lacing and truing file in Filebase, to help you get the wheels into shape
- Spock
25 Oct 2005 15:59
I have seen the Air Box Boots rotate as I slide the carbs in. This makes it real hard for them to line up.
If they are soft enough, you can rotate tthem back into alignment and then the air box boots just slide on.
Spock
Spock
