- Thank you received: 1
Throttle cable sticking!
- polkat
What is the easiest way to lube the cable? And where is the return spring (it might be weak)? Thanks!
- savedrider
- 1975 Z1-B 900
Not sure why it would make a difference hot vs. cold though.
Get right or get left! <*{{{><
- polkat
- savedrider
- 1975 Z1-B 900
The return spring should be on the carbs, not in the throttle twist assembly. Usually the springs are pretty resilient.
- polkat
Yea, that's what I was asking. How? I am assuming that you take the throttle apart at the handlebar and squirt the stuff down the cable...right?
Is the throttle return spring(s) at the carbs a single spring, or do all 4 carbs have one?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
A cheap and effective alternative is to use a sandwich bag as a funnel. Once you have the end of the cable free from your throttle, poke it thru a corner of the bag then use an elastic to hold it tightly in place. Tape the bag to your bars, then fill it with some oil.
When the oil runs out the other end, you're done!
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Bluemeanie
- Thank you received: 14
- polkat
Once the engine has warmed up, and the choke is off, the problem is mostly gone.
- hoghaterkaw
As I mentioned in the original post, this only happens when the bike is cold and the choke is on. I realize that the engine will rev higher when the choke is on. that's not the problem. If I tweak the throttle during warm up for an instant, say up to 4000rpm, it stays at 4000rpm when I release the throttle. I then have to kill switch it to stop it. After that it's okay again until I tweak the throttle...problem repeats.
what you just stated about adding throttle while on choke and a cold motor is typical of these bikes. not a cable issue.
- YUKABODOS
I had a problem with the return when I swapped out handle bars and lubed the cables to no effect, not until I removed the tank the return operated as normal. The problem was a simple fix, but is almost too simple to even consider.
- polkat
