76 kz900 low rpm issue
- vict182
Here is my problem
Bought a 76 kz900.
77 kz1000 vm26 carbs, 77 kz1000 stock airbox, 4in1 exhaust.
Everything worked fine, well tuned.
Put a k&n air filter element in the stock airbox, and a kz1000j 4in2 stock exhaust.
Now has little but annoying hesitations at low rmp when i give a little gas, cruising at low rpm. as soon as i give more gas hesitation disappears and runs fine. during this "running fine" in the way to redline, there is less torque than before but well i'm not looking for a race bike so i can stand it. what i can't stand are those hesitations at low rpm with little gas.
Playing with pilot adjustment screw doesn't really help. anyway it seems that turning them out the problem decreases.
How can i fix it?
thanks
- keith1
- Thank you received: 2
apparently that bike is way more sensitive on the intake side....my waguess is that if you put stock air filter back in and its better, if you want to run k/n, go up 1 size on pilot.....hope this helps.....
- roy-b-boy-b
- Thank you received: 103
- nads.com
- Thank you received: 20
- vict182
thanks a lot!
- bountyhunter
- Thank you received: 337
When I had that problem, the biggest "fix" for it was to raise the carb needles a slot or even 1/2 slot.Hi all
Here is my problem
Bought a 76 kz900.
How can i fix it?
thanks
The pilot jets did improve it a little but not enough to cure it. Needle position was dead on it, one slot makes a huge difference in off idle throttle response.
- timebomb33
I THINK MY POWERBAND BROKE
- rosken
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Up 1 on pilot, and lower needle clip position (raise needle) to richen off idle to almost 3/4 throttle.
If your anxious to ride, the main can be tuned later with your butt-dyno!
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Bluemeanie
- Thank you received: 14
thanks
My 650 also went from a Kerker 4-1 to a stock 4-2 exhaust. I also run a K&N in the stock airbox and feel the same thing you do. First of all your going to lose some torque at higher RPMs with stock exhaust. My bike feels softer near redline but pulls much better on the bottom end and at midrange (which is where we ride 90% of the time) I adjusted my floats which were ALL high and noticed a smoother, better responding motor. But still have a slight hesitation at lower R's. I agree with bumping the pilot jets up a size to help with lower RPM response.
- vict182
@all:
don't think it's an electrical problem, as i hadn't had it before to make those changes on the bike.
replaced k&n with stock element, no difference.
while playing with pilot screws noticed some improvement turning them out.
will try to replace the 4in2 with the old 4in1 just to make sure that this issue is caused by this change, before to start playing with jets.
any other suggestion will be great!
- Thank you received: 2098
...while playing with pilot screws noticed some improvement turning them out....
FWIW, turning side-located pilot screw out counter-clockwise leans out the pilot mixture by introducing more air. Edit -- as later noted, the carbs at hand have bottom-located pilot screws which turn out counter-clockwise for richer and turn in clockwise for leaner.
Clean pilot circuit is critical to lower rpm performance and performance during first 1/4 throttle. And critical to smooth strong pull away from idle without hesitation or stumble.
If not already done, would also check float bowl fuel levels (using the clear tube test method). Edit -- I see this has been done.
Good Luck!
