76 kz900 low rpm issue
04 Nov 2009 14:35 #331546 by vict182
76 kz900 low rpm issue was created by vict182
Hi all
Here is my problem
Bought a 76 kz900.
77 kz1000 vm26 carbs, 77 kz1000 stock airbox, 4in1 exhaust.
Everything worked fine, well tuned.
Put a k&n air filter element in the stock airbox, and a kz1000j 4in2 stock exhaust.
Now has little but annoying hesitations at low rmp when i give a little gas, cruising at low rpm. as soon as i give more gas hesitation disappears and runs fine. during this "running fine" in the way to redline, there is less torque than before but well i'm not looking for a race bike so i can stand it. what i can't stand are those hesitations at low rpm with little gas.
Playing with pilot adjustment screw doesn't really help. anyway it seems that turning them out the problem decreases.
How can i fix it?
thanks
04 Nov 2009 14:59 #331549 by keith1
Replied by keith1 on topic 76 kz900 low rpm issue
i would put the old air filter element back in and see what happens....kind of wierd...you went from 4-1 to a stock system but also switched from stock paper filter to k/n....
apparently that bike is way more sensitive on the intake side....my waguess is that if you put stock air filter back in and its better, if you want to run k/n, go up 1 size on pilot.....hope this helps.....
04 Nov 2009 15:12 #331550 by roy-b-boy-b
Replied by roy-b-boy-b on topic 76 kz900 low rpm issue
I second the going up one size on the pilots. Roy
04 Nov 2009 15:30 #331554 by nads.com
Replied by nads.com on topic 76 kz900 low rpm issue
Got low voltage to the coils? Got enough amperage there? Try running a good wire from the batt. to the coils and take it for a ride.
05 Nov 2009 00:13 #331619 by vict182
Replied by vict182 on topic 76 kz900 low rpm issue
Ok will give a try to your suggests, and i'll keep you adviced.
thanks a lot!
05 Nov 2009 11:01 - 05 Nov 2009 11:03 #331660 by bountyhunter
Replied by bountyhunter on topic 76 kz900 low rpm issue
vict182 wrote:
Hi all
Here is my problem
Bought a 76 kz900.
How can i fix it?
thanks
When I had that problem, the biggest "fix" for it was to raise the carb needles a slot or even 1/2 slot.
The pilot jets did improve it a little but not enough to cure it. Needle position was dead on it, one slot makes a huge difference in off idle throttle response.
Last edit: 05 Nov 2009 11:03 by bountyhunter.
05 Nov 2009 11:29 #331661 by timebomb33
Replied by timebomb33 on topic 76 kz900 low rpm issue
i second raising the needle your a bit lean in the transition area between the pilot and the midrange i'd try one clip position to begin with my self
I THINK MY POWERBAND BROKE
05 Nov 2009 12:53 #331668 by rosken
Replied by rosken on topic 76 kz900 low rpm issue
i had the same symtoms when i put a 716 big bore kit on my z650,(pod filters) went up on the pilot jets and this cured the problem
  • TeK9iNe
  • What did you do!?!
05 Nov 2009 13:58 - 05 Nov 2009 13:58 #331671 by TeK9iNe
Replied by TeK9iNe on topic 76 kz900 low rpm issue
Intake side changes have a dramatic effect. The advise here already will get you going fine.
Up 1 on pilot, and lower needle clip position (raise needle) to richen off idle to almost 3/4 throttle.
If your anxious to ride, the main can be tuned later with your butt-dyno!
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 05 Nov 2009 13:58 by TeK9iNe.
06 Nov 2009 05:45 - 06 Nov 2009 05:49 #331725 by Bluemeanie
Replied by Bluemeanie on topic 76 kz900 low rpm issue
thanks
My 650 also went from a Kerker 4-1 to a stock 4-2 exhaust. I also run a K&N in the stock airbox and feel the same thing you do. First of all your going to lose some torque at higher RPMs with stock exhaust. My bike feels softer near redline but pulls much better on the bottom end and at midrange (which is where we ride 90% of the time) I adjusted my floats which were ALL high and noticed a smoother, better responding motor. But still have a slight hesitation at lower R's. I agree with bumping the pilot jets up a size to help with lower RPM response. ;)
Last edit: 06 Nov 2009 05:49 by Bluemeanie.
06 Nov 2009 14:32 #331818 by vict182
@Blue: so you still have this problem?
@all:
don't think it's an electrical problem, as i hadn't had it before to make those changes on the bike.
replaced k&n with stock element, no difference.
while playing with pilot screws noticed some improvement turning them out.
will try to replace the 4in2 with the old 4in1 just to make sure that this issue is caused by this change, before to start playing with jets.
any other suggestion will be great!
06 Nov 2009 14:50 - 07 Nov 2009 06:56 #331820 by Patton
Replied by Patton on topic 76 kz900 low rpm issue
vict182 wrote:
...while playing with pilot screws noticed some improvement turning them out....
FWIW, turning side-located pilot screw out counter-clockwise leans out the pilot mixture by introducing more air. Edit -- as later noted, the carbs at hand have bottom-located pilot screws which turn out counter-clockwise for richer and turn in clockwise for leaner.
Clean pilot circuit is critical to lower rpm performance and performance during first 1/4 throttle. And critical to smooth strong pull away from idle without hesitation or stumble.
If not already done, would also check float bowl fuel levels (using the clear tube test method). Edit -- I see this has been done.
Good Luck! :)
Last edit: 07 Nov 2009 06:56 by Patton.
