77 kz1000 stock carbs tuning
- vict182
02 Nov 2009 07:17 #331079
by vict182
77 kz1000 stock carbs tuning was created by vict182
Hi all
I have a problem with a 1977 kz1000.
I have worked on a kz650 with vm24ss stock carbs and on a 1976 kz900 with vm26ss stock carbs too.
They both have the pilot adjusting screw at the bottom of the float bowl, and the air/fuel mixture adjusting screw on the side of each carb. I had the service manual so it was easy to understand how to tune up the carbs.
Now this 77kz1000 has vm26ss stock carbs but there isn't any air/fuel adjusting screw on the side! i had a look at the diagrams and it seems normal.
Since i have not the service manual for this bike (i could really use one but seems to be impossible to find on internet and on ebay too), could someone please tell me why they not have this screw and how is it supposed to tune up the air/fuel mixture on this carbs?
And i need another confirm: so 76 kz900 and 77 kz1000 have stock vm26ss carbs but they are different!
Many thanks
Many thanks
- timebomb33
- Thank you received: 10
02 Nov 2009 07:43 #331080
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 77 kz1000 stock carbs tuning
the carbs that don't have an air screw has a pilot fuel screw located at the front of the carb in front of the float bowl it a adjustable from the bottom set it to 1 1/2 turns out to start.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
02 Nov 2009 08:12 #331085
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 77 kz1000 stock carbs tuning
Because its a pilot fuel mixture screw on the engine side, it works the opposite of an air screw found on the filter side of the carb.
Pilot mixture screws: Out = more fuel mixture. In = less fuel mixture.
Air screws: Out = more air to mixture. In = less air to mixture.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- vict182
02 Nov 2009 09:15 #331089
by vict182
Replied by vict182 on topic 77 kz1000 stock carbs tuning
Thanks a lot for your answers!
And forgive my bad english
So, i'm right when i say that:
77kz650 vm24ss have BOTH air screw on the side and pilot screw on the bottom
76kz900 vm26ss have BOTH air screw on the side and pilot screw on the bottom
77kz1000 vm26ss have ONLY pilot screw on the bottom
P.S. any suggestion about where to find a service manual for a 77 kz1000 will be very appreciated!
- Bluemeanie
- Thank you received: 14
02 Nov 2009 13:14 - 02 Nov 2009 13:14 #331128
by Bluemeanie
Replied by Bluemeanie on topic 77 kz1000 stock carbs tuning
Here's a
Factory Service Manual
for a '77 KZ1000 LTD, it should work?
Last edit: 02 Nov 2009 13:14 by Bluemeanie.
- vict182
02 Nov 2009 14:47 #331141
by vict182
Nope
That is the supplement for the ltd model
Is a short manual that points out the differences of the ltd model compared to the main model
I'm looking for the main manual
thanks anyway
thanks anyway
- netcats
02 Nov 2009 16:58 #331174
by netcats
Replied by netcats on topic 77 kz1000 stock carbs tuning
Hello,
Go back to the link on Ebay and check out the service manual from classicbikes in New Zealand it's the red manual and it will cover all the versions of your bike.
I have the one for the Kz650 and it is an exact reprint of the factory manual and it has a laminated cover to boot.
I think it's an excellent deal. Just like having a complete set of updates.
Best regards, Netcats
- keith1
02 Nov 2009 17:11 #331179
by keith1
Replied by keith1 on topic 77 kz1000 stock carbs tuning
vict182 wrote:
for what its worth, i have a clymer from 77 that covers 900 and 1000 cc fours and has a 1/2 inch section for the 77 kz1000 and a hop -up section for the old 4's.....well worn, but vintage and cool.....let me know if you are interested.....
Nope
thanks anyway
