accelorator pump
- irish mike
- 79 kz 650 b3 rat rod
28 Oct 2009 16:40 #330163
by irish mike
accelorator pump was created by irish mike
hi everybody just pulled my pump apart to rebuildit -i bought a kit but cant figure out where the little ball bearing goes[maybe the previous owner pulled it apart and never put it back]icant find it in my clymers manual either-ihate it when ihave parts left over .lol.... thankz everyone mike;;;;
- Bluemeanie
- Thank you received: 14
28 Oct 2009 18:21 - 28 Oct 2009 18:22 #330196
by Bluemeanie
Replied by Bluemeanie on topic accelorator pump
Last edit: 28 Oct 2009 18:22 by Bluemeanie.
- timebomb33
- Thank you received: 10
28 Oct 2009 18:24 #330198
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic accelorator pump
is no14 the ball bearing that your talking about.
- irish mike
28 Oct 2009 18:57 #330214
by irish mike
Replied by irish mike on topic accelorator pump
thanks every body idont know if that is the ballbearing or not =it seems that that is part of the carb =idont know if that would be included in a pump rebuild kit or not-but ill check it out again tomorow[2 dark now].i cant run the bike to see if its running ok right now[my buddy blew up my tank trying to get a dent out]but ill keep plugging away at this project untill its just right thanks again mike....
- Bluemeanie
28 Oct 2009 19:45 #330230
by Bluemeanie
Carb kits will not include those balls (one per carb) As a matter of fact there are no rebuild kits for the "pumper carbs". You have to use standard rebuild kits, everything works except the bowl gaskets. They must be ordered seperatly as they have a cut out for the one way check valve. Are you talking about rebuilding the carbs or the accelerator pump itself?
- JMKZHI
- Thank you received: 48
28 Oct 2009 20:09 - 28 Oct 2009 20:10 #330235
by JMKZHI
Replied by JMKZHI on topic accelorator pump
The K&L accelerator pump rebuild kit typically has the ball, weight & spring clip. To check the accelerator pump circuit, supply the carbs w fuel, then actuate the throttle pulley vigorously - fuel should squirt out the pump nozzles straight back thru the carb bore without hitting the walls.
Last edit: 28 Oct 2009 20:10 by JMKZHI.
- irish mike
28 Oct 2009 20:38 - 28 Oct 2009 20:40 #330240
by irish mike
thanks again -i did use the k&l rebuild kit -now i know where the ball goes[excuse my language...lol]ihad some gas leekingout and when i pulled it apart both gaskets were worn pretty bad but all is well now thanks again mike;;;;
Last edit: 28 Oct 2009 20:40 by irish mike. Reason: forgot a word
