77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
- YUKABODOS
26 Oct 2009 09:06 #329724
by YUKABODOS
77 C1 - Rebuilt Carbs:Now no fuel in #4 What the? was created by YUKABODOS
Guys:
Rebuilt the carbs (COMPLETE TEAR DOWN) yesterday because #2 cylinder was not firing. Rebuilt all 4 carbs. #2 was a mess internally and cleaned up well. Reinstalled the carbs on the bike and fired her up let her run for a few minutes and check the headers.
#4 was now ice cold. Pulled the drain plug on number 4 and not a drop of gas, the bowl was dry. Then removed the bowl to check to see if the needle and seat were working and everything appeared normal. Still no gas.
Anyone experience this before or have a solution or a possible way to tackel this problem? The other three carbs are working fine.
Thanks
Thanks
- timebomb33
- Thank you received: 10
26 Oct 2009 10:54 #329734
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
you must have some very serious blockage on the supply side of the carbs i'd remove them pull out all the float valves and blow thru them with compressed air that should get rid of your problem.
- JakeB
26 Oct 2009 12:32 #329747
by JakeB
1978 Z1-R
Replied by JakeB on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
Check to make sure the float isn't installed upside down.
It happened to this guy I know. :blush:
1978 Z1-R
- YUKABODOS
26 Oct 2009 14:34 - 26 Oct 2009 14:35 #329758
by YUKABODOS
Replied by YUKABODOS on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
The Floats are in the right way, I checked for the ware mark and made sure the tab was oriented in the right way. THe new needle and seat are working.
I will have to pull them back off of the bike and break them off of the rack it seems to determine why or if there is a blockage.
I have a compressor to blow through them, but I am sure that when I assembled them yesterday there were no blockages. I mean it would have to be one hell of a blockage wouldn't it? I sure as hell didn't put a cork in there.
Carbs are fun aren't they?
Anyone else have any ideas? I will post again tomorrow once I can get a better look at them.
Last edit: 26 Oct 2009 14:35 by YUKABODOS.
- spudbudy
- Kick it like you mean it
26 Oct 2009 15:09 #329761
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Replied by spudbudy on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
Take the needle seat out and look and see if it's blocked underneath. very easy to miss this blockage.
- Bluemeanie
- Thank you received: 14
27 Oct 2009 05:38 - 27 Oct 2009 05:40 #329906
by Bluemeanie
Replied by Bluemeanie on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
Yes, remove carbs from bike but you don't need to remove from rack. If you have a manual, use a carb flow diagram and follow the fuel flow with carb spray, air, etc, until you find the blockage. The fuel flow into bowl is very simple so you should find problem quite easily. Also make sure float is NOT catching on something as bowl is installed. This will raise float and shut off fuel real quick! It happened to me once! :blush:
Last edit: 27 Oct 2009 05:40 by Bluemeanie.
- YUKABODOS
27 Oct 2009 08:48 #329922
by YUKABODOS
Well gents thank you for your reply's.
I got the bike purring like a kitten. Not bad for $400.00
The problem with the carb #4 not getting any fuel was that I rebuilt them in the wrong sequence. #3 & #4 were put on in the wrong order and as a result no fuel would flow because there is no passage way.
(HOW FREAKING STUPID!!) But this is my first time rebuilding the carbs so hell I figure I learned something.
After, I swaped out the carbs and reaseembled the carbs on the rack, which took about 25 mins,I used the wire method of bench syncing the carbs. That got the slide looking reasonably positioned. I threw them back onto the bike, which only took about 10 mins (I bought new boots at Z1). After buttoning her up I put the sync guage on and was amazed to see the carbs only slightly out and Number 1 was almost bang on the factory setting.
After another 10 mins or so the bike ran like a top and I had saved another KZ from the scrap yard.
Yukabodos Buddy!!!
:blink:
Yukabodos Buddy!!!
:blink:
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Oct 2009 14:24 #329957
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- fixer5000
- Thank you received: 5
27 Oct 2009 15:01 #329961
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic 77 C1 - Rebuilt Carbs:Now no fuel in #4 What the?
i actually numbered mine so i wouldnt do that!!!
massachusetts
- Bluemeanie
28 Oct 2009 05:29 #330052
by Bluemeanie
Good for you! Always good to see a solution posted!
