- Thank you received: 511
Removing end carbs , help please
- bluej58
It seems I have the dreaded leaky fuel joint syndrome and I plan on trying (money pits) shrink tubing trick, what are the problems involved with removing the out side carbs.
Should I wait till I get the shop manual or is it fairly simple, thanks JD
78 KZ1000 A2A
- roy-b-boy-b
- Thank you received: 103
There is a lot of pieces but you should be able to handle it. Roy
- JMKZHI
- Thank you received: 48
I used 4 plastic divided lunch containers to keep the parts organized. Do the disassembly on an uncluttered table. Don't drop the carbs onto the floor - I've heard some sad tales. Working on top of big towel helps to contain the parts & offers padding. Use good fitting tools, especially on the brass parts.
- bluej58
KZTOOA-519130 they say that there is no match.
What am I doing wrong ?
78 KZ1000 A2A
- Thank you received: 2098
Thanks for the replys, I keep trying Kawasaki.com and I get to were they ask for the VIN# but when I type in
At kawsaki.com, on the motorcycle choice page, just select ONLY the year 1978.
Then continue without entering any other information.
A list of the 1978 models will appear. Just scroll down to your bike, and click on it.
On the next screen, click on Parts Diagrams.
Then select from the list of diagrams.
Good Luck!
- Thank you received: 797
above is the address to a breakdown of your carbs.babbits is great for looking at diagrams.quick and easy
hth,
leon holmes
- bluej58
But Babbits was easy,thanks
78 KZ1000 A2A
- bluej58
What am I missing, It can't be that easy.
78 KZ1000 A2A
- JMKZHI
As for the diagrams, the vin lookup doesn't work for the early models - it only functions for the later 1980 or 81 17-digit vins. So use the Search-by-Model-Info:
Kawasaki.com -->> Owner Info -->> Parts diagrams -->> Search-by-Model-Info -->> Continue. On the new page choose a year only & click Continue again. Then pick a bike from the list. Cross-reference & other info is available in the diagrams - click stuff.
PS: I don't know if the outer carbs can be removed without separating the other carbs from the mounting plate.
- bluej58
Got the old girl fired up today, first time since 92
I kinda forgot how good she sounds, now I'm getting pumped.
78 KZ1000 A2A
- keith1
