- Thank you received: 1
KZ650 Head Looking For VM28's
- Becker
- The Doctor Will Rise Again
14 Oct 2009 19:50 #327598
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
KZ650 Head Looking For VM28's was created by Becker
I'm already in full swing on building my KZ650C3 into an 810. My question is How do I tell the difference between VM28's and VM26's on Ebay. Everyone with a set listing on ebay just says that they came off a KZ1000 without listing the size. What are some visible Differences??
Also what do I need to do to the carb holders to make this work?? just buy KZ1000 carb holders and slot them out?? Any help would be appreciated.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- FloridaSteve
17 Oct 2009 08:21 #328016
by FloridaSteve
Replied by FloridaSteve on topic KZ650 Head Looking For VM28's
Go here. this was a huge help to me when I was looking around.
www.z1enterprises.com/reference/z1-carb-guide.aspx
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
25 Oct 2009 22:31 #329665
by kzz1p
Replied by kzz1p on topic KZ650 Head Looking For VM28's
If they are 28's (like off a Z1r) they should have an accelerater pump. They have a lever in the middle between the 2 & 3 carb. that work the pump. They will fit the stock 650 intake manifolds, sometimes you need to custum fit them alittle. It is harder, if the rubber is dry and hard on the manifolds.
You can measure the dia. of the carb, where it goes into the intake manifold (should be 28mm)
- The Fish
- Thank you received: 6
26 Oct 2009 07:40 #329715
by The Fish
Replied by The Fish on topic KZ650 Head Looking For VM28's
You can tell the difference between the 26 and the 28 by the amount of "meat" where they bolt to the intake flanges.
Right side top is a 26mm (thicker mounting flanges) and the right side middle is a 28mm (thinner mounting flange)where it would mount to the intake flanges.
The top 2 sets in the center row are 2 of the Z-1 style 28mm carbs used.
Fish
Fish
- Becker
26 Oct 2009 12:34 #329748
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Replied by Becker on topic KZ650 Head Looking For VM28's
Thats exactly what I was looking for. Thanks for the picture fish.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Blue Max
06 Nov 2009 10:34 #331784
by Blue Max
Replied by Blue Max on topic KZ650 Head Looking For VM28's
The carbs in the very center of Fish's picture what are they?
- timebomb33
- Thank you received: 10
06 Nov 2009 11:28 #331790
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ650 Head Looking For VM28's
stock z1 a or b carbs from 74-75
- Blue Max
06 Nov 2009 11:38 #331792
by Blue Max
thanks timebomb for the quick answer. Could you tell me what the a or b stands for?
and also how much work would a KZ650 need to run those VM28's?
thanks in advance!
thanks in advance!
