kz 750 twin carb manifolds
- twinkyrider
10 Oct 2009 10:18 #326619
by twinkyrider
78 kz1000A
Fond du Lac,WI
kz 750 twin carb manifolds was created by twinkyrider
Is there a reason for the tube between the manifolds?
Why weren't they plugged like the fours?
Is this some kind of equalization tube to make it idle better?
78 kz1000A
Fond du Lac,WI
- bountyhunter
- Thank you received: 337
10 Oct 2009 23:29 #326743
by bountyhunter
Replied by bountyhunter on topic kz 750 twin carb manifolds
twinkyrider wrote:
It is a vacuum equalization tube to make the carbs balance better. Connect the two fittings with vacuum hose. I think you can use them to do carb balancing.Is there a reason for the tube between the manifolds?
