bench synchronization
  • oldkaw
  • oldkaw's Avatar Topic Author
19 Mar 2006 18:50
#32654
Hello fellow members !
A while back I read a post that I think wiredgeorge responded to that he gave instructions on how to bench synch your carbs before vacuum synching them. I can't find it now. Does anybody remember it or have that information ? thanks
2 1984 zn1100, 1 1985 projects
1984 zn700 oil cooler, kerker 4-1, mikuni 34's, k&n pods
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
  • The Milkman
  • The Milkman's Avatar
Re: bench synchronization
19 Mar 2006 19:54
#32684
Here is a link explaining how I did it using small balls.
kzrider.com/forum/viewthread.php?tid=15359
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Mar 2006 20:38 - 03 Dec 2008 19:52
#32694
del
Last edit: 03 Dec 2008 19:52 by JMKZHI.
  • oldkaw
19 Mar 2006 22:25
#32728
Thanks for the info Milkman and jmkzhi. I'll try the ball method tomorrow. I'm going to the hardware store and pick up some 1/8 inch balls first, of course, and remove the carbs that I can't get synched from the bike for about the 7th or 8th time. I may have to dismantle them like you did Milkman because I never did that in my initial clean up and it could be a problem.
Hopefully, I'll be able to get this bike ready to be on the road so I can catch as many good weather days as possible. Thanks again guys and I'll let you know how the ball method works for me.
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
  • gas
  • gas's Avatar
21 Mar 2006 09:51
#33071
Very cool Milkman. Glad I saw this one!
  • bemoore
  • bemoore's Avatar
25 Mar 2006 16:20
#34254
Cool writeup Milkman. Especially since I have a couple of bags of bearings for my bicycle. I have one question, though. Why is it necessary to remove the throttle return spring?
77 KZ650C1 w/Kerker 4-1
