- Thank you received: 2829
Installing bigger jets
- paulstanely45
- 1977 KZ650-B
1977 KZ650-B
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- paulstanely45
- 1977 KZ650-B
1977 KZ650-B
- timebomb33
- paulstanely45
- 1977 KZ650-B
So there is the main jet passage with the needle in it, but the passage next to it with the pilot jet, there is another just in the same passage that needs to be unscrewed before I can get to it.
Should I take some pictures or something?
1977 KZ650-B
- timebomb33
- Bluemeanie
- Thank you received: 14
I have my main jet, and then beside it, is another "jet" with a 50 stamped on it. Once removed I can access the pilot jet.
I remember WG talking about that thing, I forget what it does but if I remember right he said you can leave it off with no ill effects.
- Thank you received: 2098
Good Luck!
[Click on image to enhance view]
- anarki650
- Thank you received: 5
It's a restricting jet that was put on some of the stock set ups in an attempt to further satisfy the emission minded people...definitely not needed, especially if you've got pods and other mods that require jetting her up.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- spudbudy
- Kick it like you mean it
stock main jet was a 90.
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
- paulstanely45
- 1977 KZ650-B
I have taken some pictures of what is going on inside my carbs, hopefully this can shed some light on everything.
#1 in this picture is my main jet, #4 from what I understand is an emulsion tube.
Now, #2 Im pretty sure is my pilot jet, it has a 15 stamped on it. #3 though boggles my mind, I have no idea what it is. It has a 50 stamped on it.
#4 screws into the biggest hole in the center of the float bowl, and then #1 screws into that.
#2 screws in first in the smaller hole beside the one the main jet threads into. After I screw in #2, #3 threads into the same hole afterwards.
From what I am reading it seems that this can be omitted? Is this true?
I was thinking it may be time to rejet, get some smaller main jets, and maybe a 17.5 pilot jet.
1977 KZ650-B
