jetting after exhaust installation
  • Paul K
  • Paul K's Avatar Topic Author
06 Oct 2009 08:23
#325805
hi, i have slip on exhausts on my '76 kz400d. i hacked off the original silencers b/c they were rotten. do i need to re-jet the carbs? and if so, do i go leaner or richer? more/less back pressure = rich/lean? how does that work?
pk
  • JMKZHI
  • JMKZHI's Avatar
Re: jetting after exhaust installation
06 Oct 2009 08:37
#325808
I would look inside the mufflers & compare them if possible.
Check to see if they appear to be about the same.
If the new ones seem to be less baffled, then there would be less back pressure, so they might flow more air which would make the bike run more lean.
  • bountyhunter
  • bountyhunter's Avatar
06 Oct 2009 15:01 - 06 Oct 2009 15:02
#325859
If they are way louder than stock, you may need richer jets. If it runs good and the plugs are the right color, no worries.
Last edit: 06 Oct 2009 15:02 by bountyhunter.
